combine lift kit 2,5 + 2???
Old May 4, 2010 | 02:08 PM
  #71
MonkeyWrench4000's Avatar
MonkeyWrench4000
Originally Posted by rookie86
has anyone come out a no joke suspension lift for our trucks or you just piece one together i don't think i have the mech knowlege to do some of these things you guys are pulling off.
All you can really do is buy a leveling kit, and then you have the option of rear axle blocks, or a rear add-a-leaf. 2" all around is about the max you can get. Adding larger tires can net you about an inch of sidewall, which will get you off the ground another inch. So, 3" in total.
3" is actually a nice amount, but I am not a fan of leveling kits for the earlier posted reasons. So, besides those, there is no true-blue lift kit that keeps reliability in mind.
Old May 4, 2010 | 03:01 PM
  #72
canadian dakota's Avatar
canadian dakota
keep in mind that you can have 12" of lift but if your only running 31" tires then your still dragging your diff your true lift comes from your tires. its finding way to make bigger tires fit. now that's the trick.. all suspension is gonna get you is more articulation and a body lift will help with the tire issue..
Old May 5, 2010 | 11:19 PM
  #73
camiltster's Avatar
camiltster
Here's my project completed, for now. 3" body lift by Performance Accessories and 2.5" front coil lift made at local shop for $50. Clears 33" BF Mud Terrain tires with no problem whatsoever. Has airbags in the rear mostly just for towing purposes. My truck is the 4.7, 4x4, SLT. Mostly stock.
File Type: jpg
Old May 5, 2010 | 11:22 PM
  #74
hendrixx324's Avatar
hendrixx324
i like it
Old May 5, 2010 | 11:30 PM
  #75
canadian dakota
nice how's the install over plate under plate how the angles look please up date how cv and tie rods ware
Old May 6, 2010 | 11:36 AM
  #76
camiltster's Avatar
camiltster
I don't know the long term affects of the spacers. Only time will tell. When I had the truck on the hoist to install the spacers the upper arm was in contact with the coil spring. However, when I set the truck back on the ground it was not an issue. The front shafts are at quite an angle, however I haven't had any issues in 4wd. But I suspect there may be some wear issue problems down the road. I tore one of the cv boots during installation and so I replaced the half shaft on the drivers side.
Old May 6, 2010 | 01:41 PM
  #77
canadian dakota
pics???????? of the angle
Old May 11, 2010 | 04:18 PM
  #78
Dakkkota's Avatar
Dakkkota
Default dodgetrucker75
how much mileage have you done since you ad the custon leveling kit without problems? ?
Old May 11, 2010 | 04:19 PM
  #79
Dakkkota's Avatar
Dakkkota
camilister is that stock jeep liberty lights? you got?
Old May 11, 2010 | 06:24 PM
  #80
dodgetrucker75's Avatar
dodgetrucker75
on problems yet, but i only have 7 or 8,000 miles on the truck, had calulated milage is 15-18.5 depending on what i'm doing but the overhead display always reads 12-13
