fuel problem plz help
Old 04-19-2010 | 09:58 PM
2005dakotapa32's Avatar
2005dakotapa32
Default fuel problem plz help
i just replaced my float assembly in the gas tank and now it is hard starting and not runnin right. it is not gettin enough gas why? do i need to reset the computer or anything? i checked to see if i pinched any lines and there was nothin. plz help!!!!!!!!!!
Old 04-19-2010 | 10:08 PM
2005dakotapa32
grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old 04-19-2010 | 10:16 PM
superdak05's Avatar
superdak05
these trucks have an internal fuel filter, you may disturb enough junk in the tank to have really clogged it
Old 04-19-2010 | 10:18 PM
2005dakotapa32
it is really hard to start when im on a hill but not flat?
Old 04-19-2010 | 11:05 PM
Blown287's Avatar
Blown287
I would get a fuel line pressure gauge and check the pressure comming of the pump.
2005dakotapa32
wow!!!!!!!!!!!!!!!!!!!! i got 24 people to view my thread but only 3 replies!! wtf cmon people i need help!!!!!!!!!!!!!!!!!!!!!!!
Old 04-19-2010 | 11:08 PM
2005dakotapa32
it worked perfect before i changed the float and i only changed the float cuz my gauge stopped workin. now the gauge works but im not gettin enough gas when im on a hill
Old 04-19-2010 | 11:10 PM
Blown287's Avatar
Blown287
Not everyone will have ideas. I would
#1 check fuel line pressure. If the fuel line is comming to correct pressure, you can probably ruel out fuel filter.
#2 relieve pressure from the fuel ine by pressing the schrader valve on the fuel rail. Air in the line can create this problem. Would help explain why it doesn't want to run on hills, air is collecting in a certain spot inhibiting fuel delivery.
Old 04-19-2010 | 11:23 PM
2005dakotapa32
where is the shrader valve and fuel rail ? lmao im not a mechanic but i can do some things
Quick Reply: fuel problem plz help
