I dont think this is normal?
Old May 8, 2010 | 11:01 PM
hendrixx324's Avatar
hendrixx324
Default I dont think this is normal?
Hey guys i was chaniging my breaks today and i notice when i spun my tire back and forth the motor torqued over. Well i looked down at the motor mount and i noticed that the bushing was shot? normal or not?
Old May 9, 2010 | 12:48 PM
Blown287's Avatar
Blown287
Don't laugh but i totally broke my engine mounts last year. They are only vulcanized rubber, energy suspension is supposed to be making a better mount (polyeurothane) but they are not on the market yet. Our engine mounts are garbage.
Old May 9, 2010 | 08:20 PM
hendrixx324
oh well thats good. Im like trying to think if i hit a huge pot hole or somthin and i cant think of anything. I have to jack the engine up to change it right?
Old May 9, 2010 | 09:26 PM
Blown287's Avatar
Blown287
I went with solid (welded) tranny mounts and engine torque dampers. Of course this was after I replaced the stock mounts with a new set. I still manage to break a bolt of the torque dampers from time to time. Eventually I will get solid mounts made all the way around if Energy Suspension doesn't put their's up for sale.
Here is a thread on my mounts.
https://dodgeforum.com/forum/3rd-gen...-are-done.html
Old May 9, 2010 | 09:33 PM
hendrixx324
well you have alot more stress goin to your mounts too
Old May 9, 2010 | 09:38 PM
Blown287's Avatar
Blown287
Yep, I just wanted you to know the vulcanized rubber is not strong at all. With only the blower and putting down 300 rwhp I broke the mounts and the engine popped out its place, lol. Just letting you know the vulcanized rubber definately was not made for performance, lol.
Old May 9, 2010 | 09:40 PM
hendrixx324
so could that new trans uprade have done it? i no im not makin that much power but it shifts a hell of alot harder than stock
Old May 9, 2010 | 09:45 PM
Blown287's Avatar
Blown287
Its possible. You should try solid mounts, your ride will be a little stiffer and you will feel every shift but you won't be loosing power through those weak rubber mounts.
Old May 9, 2010 | 09:48 PM
hendrixx324
Ok ill give it a shot. I can put one solid mount for now tho right? and leave the rest until a little later. and i can just like put a 4x4 or 2 on a jack and lift the engine right?
Old May 9, 2010 | 09:50 PM
Blown287's Avatar
Blown287
Find a fabrication shop you make you a set, they are usually around 100$ or so for a customized set. I'm getting some made soon. The torque dampers just arent' holding mine in place enough. When Trucky was riding with me I kept breaking my exhaust loose, lol.
