e-fan help
Old May 18, 2010 | 05:06 PM
  #21
06firedak's Avatar
06firedak
Originally Posted by Blown287
That should work fine and looks like a fairly simple setup. Start thinking about how you want to mount it up. I mounted mine inside my strock fan shroud and just dropped it back in place. Good luck with the install.
thats what i had in mind and as soon as the parts get here i will be able to get it figured out
Old May 18, 2010 | 07:50 PM
  #23
06firedak's Avatar
06firedak
parts on order will update after install
Old May 19, 2010 | 01:13 AM
  #24
rengnath's Avatar
rengnath
Cant wait to see how it works out for ya!
Old May 25, 2010 | 02:52 PM
  #25
06firedak's Avatar
06firedak
installed and workin, just need some fine tuning. just to verify, it is supposed to pull air through the radiator not push? and still having trouble getting it figured out how to get it to com on with the ac. but this sucker moves some air so i dont see any problem keeping it cool.
Old May 26, 2010 | 11:29 AM
  #26
Slick Dakota's Avatar
Slick Dakota
yes electric fan do a better pulling then pushing and if yours is installed in the engine compartment it should be pulling air into the engine compartment..Cya Slick
