i know its beaten to death..
Old Jun 8, 2010 | 05:25 PM
Dinger838's Avatar
Dinger838
Default i know its beaten to death..
but i have a shop that will do 4,56 reverse rotation gears relatively cheap.. my cruising speed of 55-60 is around 15-1700 rpm. with 4.56 will this be around 2200 2300? will this be way overkill? need opinions quick. they said the 3.92s would only raise it 400 rpms which doesnt sound that great. and im not going through the trouble it takes for 4.10s
Old Jun 8, 2010 | 06:59 PM
rengnath's Avatar
rengnath
All I know is that sounds like a hell of alot of fun when youre not towing anything!
Old Jun 8, 2010 | 08:26 PM
Dakkkota's Avatar
Dakkkota
Default ok
all depends on the size of tire you have...my friend run 4:10 on 35'' tires and regret not to go 4:56...
but with 4:56 stock tires...forget it!
Old Jun 8, 2010 | 09:10 PM
Dinger838's Avatar
Dinger838
well with my 32s'' possibly 33s... what do ya think guys...
Old Jun 8, 2010 | 09:46 PM
rengnath's Avatar
rengnath
If you tow that boat you have in your picture alot I would go 4.56's with your 32-33" tires. I would do 4.10's with my stock tires if I had the money to do it, but I dont. Just my .02.
Old Jun 8, 2010 | 10:41 PM
JimBio's Avatar
JimBio
On my old Dakota I went from 3.92 to 4.56 and it raised my rpms approx. 400 rpms. 80mph with 28" tires was 3000 rpm, I got some 30" tires and it helped a little. The gears were a blast, no regrets what so ever. Huge increase in acceleration, slight improvement on city mileage. Negative impact was your gas mileage suffers a little on the highway. But with the larger diameter tires on the new models it probably doesn't hurt it as much.
You can go to 4lo.com and plug in the numbers to see the change in rpms
Old Jun 9, 2010 | 01:34 AM
sleds's Avatar
sleds
Dinger, are running the 3.7L? I can't remember. If so, I think the lower gears would be even better for your application.
Old Jun 9, 2010 | 11:34 AM
Dinger838's Avatar
Dinger838
yes its the mighty 3.7 i would run 4.10's but its too much trouble getting RR gears for it. 4.56 he can get. it sounds like the way to go
Old Jun 9, 2010 | 08:51 PM
Dakkkota's Avatar
Dakkkota
Default ohhh 3.7!
v6 4:56 with 33'' is the way to go give us update after its done and the price etc...
