Disabled Alarm
Newbie here, I had some transmission work done and after I got my truck back the remote key alarm system seemed to be disabled. The remote key locks do not work nor does my alarm.
Is there an on/off switch or some kind of plug that needs to be reconnected to get this stuff working again? Please advise!!!!!
I did that already thinking the same thing. Still no luck. They must have disconnected it, and I have no idea where to find a way to reconnect it.
I would take it back, but I am living elsewhere and can not take it back to them.
I wonder if the key just became de-programmed. The dealers usually charge to program a key but I don't think they charge much, that might be your issue.
Trending Topics
Guest
Posts: n/a
if the battery died it could have lost programming... but that usually doesnt happen. heck, them things usually stay programmed for a long time after the juice is gone.
I would ask them if they disconnected anything in the ignition system. like the sentry key ring that detects the chip in your key. I dont know why they would have done that for a trans, but you never know.
You can also try a local dealer. if there is a problem with the key/alarm they should be able to hook up a starscan and see the can read outs.
