Who is running 265/75/16
Old Jul 9, 2010 | 08:52 AM
motodeficient's Avatar
motodeficient
Default Who is running 265/75/16
For those of you running 265/75/16s, can you let me know how much trimming you did, if you have any rubbing, and if you have noticed any execessive problems with your front end from the bigger size tire?
I ask because its time for some new tires for my 05 dakota. I have 01 ram alloy wheels with 265/75/16 bridgestone duelers on there right now. I trimmed the splash guard and have no rubbing at all. However the tires are pretty much bald, and were maybe 1/4 tread when i put them on. So I haven't had a full height lug of this tire size on the truck ever. I want to put some new 265/75/16 uniroyal liberators on.
Old Jul 9, 2010 | 10:31 AM
bigbotes69's Avatar
bigbotes69
I have them and did NOTHING. Works just fine.
Old Jul 9, 2010 | 10:49 AM
fenwayfan25's Avatar
fenwayfan25
Running firestone 265/75/16's with no rub or problems at all. You should be ok.
Old Jul 9, 2010 | 11:19 AM
donkeypunch's Avatar
donkeypunch
King Jackass
I am running Goodyear Authority A/T's, 265/75/16s. Had to trim the front flaps a little. I still get a little rub while braking and turning (hard). I also have a TM 1.5" leveling kit.
Old Jul 9, 2010 | 11:35 AM
rengnath's Avatar
rengnath
Bigbotes or fenway,
Do either of you guys have leveling kits?
And do you have 2wd or 4wd?
Old Jul 9, 2010 | 11:37 AM
motodeficient
I don't have a leveling kit which is worrying me a little bit as far as rubbing.
Old Jul 9, 2010 | 11:59 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I had 265/75 R16 on the stock steelies for a while, everything worked fine. Looked good too. No rub at all with BFG ATs. However, I had BFG MTs and they appeared like they would of rubbed if I had mounted them in comparison to the ATs.
With that being said, I have had 3 power steering racks replaced. The dealership blamed the leveling kit. I took it out, everything was fine from then on out, even with the larger tires.
Once the tires wore off, I went back to factory size and never looked back.
Most mechanics I spoke to on the matter blamed the leveling kit, and some blamed the heavier tires.
Either way, I'm never messing around with that junk again. Personally, I wouldn't bother with larger tires.
But, if you don't plan to level, your truck will probably be fine running them.
Old Jul 9, 2010 | 12:04 PM
what about that size with 17" rims?
Old Jul 9, 2010 | 12:24 PM
motodeficient
I think you would have to go with a 265/70/17 instead of the 65 series.
So it seems to me that the leveling kit may cause more wear on the front end parts than the larger tires
Old Jul 9, 2010 | 12:48 PM
bigbotes69's Avatar
bigbotes69
Rengnath, no leveling kit, all stock. 2wd
