so on my way hme today CEL went on.
Old Jul 10, 2010 | 01:36 AM
hendrixx324's Avatar
hendrixx324
yea il try that and what does a bad water pump sound like. Cuz the shop said i had a noisy waterpump
Old Jul 10, 2010 | 01:38 AM
Blown287's Avatar
Blown287
A bad water pump will usually leak at the seals, engine will run warm and when the bearings start to go it will sound like rolling gravel. When it locks it won't turn at all and can smoke your belt if you attempt to engage the A/C with the bearings shot.
Old Jul 10, 2010 | 01:42 AM
hendrixx324
oh good thing i didnt have the guys replace it cuz i have none of that could belt slippage cause a tad bit of overheating?
Old Jul 10, 2010 | 01:50 AM
Blown287's Avatar
Blown287
Well, the belt can slip if the gears in the pump are going bad.
http://www.youtube.com/watch?v=4RWfvG25NKI
Overheating can be cause by the waterpump going out, air in the system, faulty thermostat etc.
Old Jul 10, 2010 | 02:03 AM
hendrixx324
well evcerything is rerplaced expcept for the water pump and thats sorta the nboise i hear i guess. It doesnt over heat it just runs hot on hot days. almost like the waterpump cant keep up with it
Old Jul 10, 2010 | 02:08 AM
Blown287's Avatar
Blown287
Yeah, you probably better switch it out. I have an aftermarket waterpump in the garage that I've been keeping around just in case, lol. It will probably only take you about 30 minutes.
Old Jul 10, 2010 | 02:10 AM
hendrixx324
i no its an easy job in a chevy. Next pay check ill buy that and thaqt HHR fan you started a thread on hah. I want that
Old Jul 10, 2010 | 02:21 AM
Blown287's Avatar
Blown287
Thanks brother, I've been really impressed with the HHR fan so far.
Here is the pump I have on standby in the garage, lol. One of many extra Dakota parts I keep around.
Old Jul 10, 2010 | 07:06 PM
Moneyman19's Avatar
Moneyman19
when u look at ur water pump from the top u should see a little hole if u see sum coolant laying around time to change. if not or if ur fan bearings go u will blow ur pump... trust me its happen to me 4 times in my dakota because the guys at the dealership didnt see that they were bad... its pretty much an easy switch. the seals will leak as well and she will run warmer then usual.
Old Jul 10, 2010 | 11:43 PM
hendrixx324
ill take a look thanks.
