Adding a Temperature Gauge
Old Jul 14, 2010 | 07:59 PM
pojv's Avatar
pojv
Default Adding a Temperature Gauge
Has anyone replace the Hex-Bolt in the top of the thermostat housing with a temperature sending unit for an aftermarket temp gauge?
Phil
Old Jul 14, 2010 | 09:01 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Phil
I am not sure anyone has used that location for an aftermarket gauge, but it could be done. Some have used that location for the temp sensor for an e-fan. Basically what you are looking to do.
Old Jul 14, 2010 | 10:39 PM
Blown287's Avatar
Blown287
Phil
I tried it once but ended up piggy backing of the stock oem water temp sensor instead.
Old Jul 15, 2010 | 12:33 AM
pojv's Avatar
pojv
Thank you for your input.
Phil
Old Jul 15, 2010 | 02:29 AM
hendrixx324's Avatar
hendrixx324
cant you put the probe thing in the tempator warning sender? it should be locvated on the intake manifold
Old Jul 15, 2010 | 08:21 AM
lghtngblt02
Phil
No problem! Good luck!
You lost me Hendrixx?
