Load levelers, Air bags, et al
Old Jul 19, 2010 | 06:19 PM
hwcurtice's Avatar
hwcurtice
Default Load levelers, Air bags, et al
So, what have you installed? Which works best? I've seen some from Firestone and some from a place called Airbagcompany.com
I just want something on the truck for those time when the leaf springs go flat, which isn't a good thing...
Old Jul 19, 2010 | 11:28 PM
HammerZ71's Avatar
HammerZ71
Air Lifts on my truck. I went to a buddy of mine who owns a couple of tire stores to order me a set of Firestone bags. I knew he sold/installed quite a few to farmers who towed/hauled all the time.
He talked me out of the Firestones at the time because he said a LOT of sets he installed were having issues with the bags dry rotting after only a couple years. He since started selling Air Lift bags and never had the issue. So I bought the Air Lifts on his recommendation. Good thing too, because I later lifted my truck and the Firestone mount system is a no go with a body or suspension lift.
Love mine, use them often...
Old Jul 20, 2010 | 12:43 PM
hwcurtice's Avatar
hwcurtice
'Air Lifts'? From where?
Old Jul 20, 2010 | 02:00 PM
HammerZ71's Avatar
HammerZ71
I got my buddy to order it from his wholesaler, but his cost was $181 (saw the invoice myself) and I've seen 'em for about the same price on Amazon.com.
Any truck accessory place would have/can get them. Summit, 4 Wheel Parts, LMC Truck, Jeggs, etc. Hell, even Advance Auto lists them, most stores get them from local warehouse in a day, but they want like $239 for 'em...
Here is the set I have, even cheaper than what I paid "wholesale". I'm assuming since my Ram and a Dak has the same rear it'll fit, but check to be sure:
http://www.amazon.com/LIFT-59501-Con...9648952&sr=8-1
I didn't mess with the on-board compressor or auto level kit or any of that stuff, just mounted the included fill valve on my receiver hitch:
Old Jul 20, 2010 | 02:35 PM
hwcurtice's Avatar
hwcurtice
According to Amazon.com, that particular kit don't fit the 2006 Dakota. They have this one: http://www.amazon.com/LIFT-59555-Con...tive&carId=001
BUT it looks very similar to the one that does that I saw on http://www.airliftcompany.com/index....bagcompany.com not airbagcompany.com
Oh, it is the same one... DOH! Now I need to compare prices....
Old Jul 20, 2010 | 02:37 PM
hwcurtice's Avatar
hwcurtice
And somehow, I'm planning on a compressor as it always seems that I need the extra lift when I don't have available compressed air around. Like out in the woods, or at Home Depot...
Old Jul 20, 2010 | 02:50 PM
dodgetrucker75's Avatar
dodgetrucker75
i run air bags only in the rear of my 75, i pulled an automatic height control valve off of a semi, and hooked it up to my bags, then ran a 12v compressor straight to the valve with no tank, so it always stays in the same position at all times, if i put a load on it the comp cycles for just a second to mantain height, then if i remove the load, the valve releaces presseure, just a thought, it works really well for me
Old Jul 20, 2010 | 03:05 PM
HammerZ71's Avatar
HammerZ71
I didn't mess with it as I keep a 12v compressor in my toolbox, have a large compressor in my garage, have a 220v compressor at the farm and keep a small 12v in my ATV (and it has a 12v plug). Just an expense I didn't figure I needed.
My ATV is the reason I bought it. Because of my toolbox, almost ALL of it's 700# resides behind my rear axle. Made my low beams hit the tree tops at night! Rear end actually sat lower with the ATV in the bed than when I pull the 7700# tractor.
Max capacity of the bags is 100# of air and just 30# keeps me dead level with the ATV in the bed.
Old Jul 20, 2010 | 03:22 PM
hwcurtice's Avatar
hwcurtice
It's mostly finding a place to stick the compressor where its not only protected from the elements, but also not blocking anything. I don't really want a tank anywhere as that is just a lot of weight I really don't want or need. I'm not running an air horn on this... yet...
