Not a typical CAI question, please read.
It wouldnt hurt to do it, but I doubt you will gain anything on a stock motor. There is only so much restriction that comes from your stock intake, which is reduced greatly with a CAI. Then, the restriction comes from your throttle body, intake manifold, heads and exhaust. The engine will only suck in as much as it can put out. So it would be more for looks than actual function. If you want to help your current CAI out, the best thing you can do is get the most cold air to it as you can via a hood scoop or ram air system. Until you reduce the other restrictive factors on the engine, there would be no need for a dual intake .... and even after doing all that other stuff Im not sure if you would need it. My .02
ok, thanks guys. I dont think I will be able to do any $$$ mods for awhile since I bought this: http://www.auterraweb.com/dashdynoseries.html
I am going to use this to track down and clear the trouble codes on my wifes van which I believe is one of the o2 sensors. Then use it for tweaking my truck.
BTW, anyone heard anything more recently about the tuners for 3.7L? (I have already been pointed to the other forum with the request form)>
