Coolant ?
Old Jul 22, 2010 | 08:43 AM
dakota_raven's Avatar
dakota_raven
Default Coolant ?
My Dak has that orange looking Mopar coolant. The question is : can i mix that Mopar coolant with an over the counter one like Prestone or any other green coolant? Thanks !
Old Jul 22, 2010 | 10:53 AM
dodgetrucker75's Avatar
dodgetrucker75
dont mix with the green stuff, it can cause all different kinds of hell
Old Jul 22, 2010 | 10:55 AM
lmrjason's Avatar
lmrjason
don't mix it
Old Jul 22, 2010 | 11:16 AM
dakota_raven
Ok! Don't mix it, got it! So, where i can buy that factory coolant? On the dealer? Can i buy it online? Or should i do a system flush and use the green one? Suggestions please!
Thanks!!!
Old Jul 22, 2010 | 01:23 PM
lmrjason's Avatar
lmrjason
i think it's called zerex g-05...the only place around here that carries it is napa.
Old Jul 22, 2010 | 02:29 PM
popsnbeer's Avatar
popsnbeer
. I did mine w/ zerex g-05 from napa too.
Old Jul 22, 2010 | 03:03 PM
dakota_raven
Hey pops! Did you mix it or you got the system flushed and then used Zerex??
Old Jul 22, 2010 | 04:31 PM
popsnbeer's Avatar
popsnbeer
I did it when I changed my thermostat. Not a full flush. I figured that if the coolant is the same, it's not a problem. I think the issues arise if you introduce a different type of coolant in the mix. Not sure though...I probably should flush it and get my ratio right again!
Old Jul 22, 2010 | 05:36 PM
dakota_raven
Thanks...
