just dont get it
Old Aug 5, 2010 | 03:23 PM
keithhud's Avatar
keithhud
Blown is on the right track. With the pressurize cooling system that our trucks run, if you get an air bubble in the system it can cause the truck to overheat or run hot. It sounds like there is air in the system.
I know it’s after the fact, but it’s a good practice to measure the coolant that comes out and then you know what needs to go back in.
Do you have a local shop around that you can ask how they pressurize cooling systems?
Old Aug 5, 2010 | 07:05 PM
hendrixx324's Avatar
hendrixx324
theres a bunchof shops around here that ill ask. but does anyone here know how to bleed it. SOmbodhy at my work told me that a 3000cfm fan isnt strong enoughj to run a/c and have a transcooler.
Old Aug 5, 2010 | 07:18 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Turn the cap alittle and run it around... for awhile...
Just curious, is your Thermo in backwards?
Old Aug 5, 2010 | 07:31 PM
dodgetrucker75's Avatar
dodgetrucker75
where the top radiator hose hooks to the engine there should be a pipe plug, takes an allen wrench to remove
Old Aug 5, 2010 | 09:54 PM
hendrixx324
my stats fine because wghen i instaled it first it was in backwards and it overgheatedf realy fast. Then i flipped it around and it was good hahha.
Old Aug 5, 2010 | 09:55 PM
hendrixx324
hey blown you said you had no problem with overheating right?
Old Aug 5, 2010 | 10:04 PM
Blown287's Avatar
Blown287
I did when the head gasket failed due to radiator fluid running down the side of the block. Until then, no.
With the engine cold, remove the radiator cap. Fill the radiator tube to the top. Start the truck and watch for bubbles to purge from the system. Continue to fill as the bubbles purge out. After about a minute or two kill the truck and put the cap back on. The next day repeat until the fluid is at the cap level.
There is also a radiator bleeder valve that Dodgetrucker mentioned. You can use that. Good luck.
Old Aug 5, 2010 | 10:06 PM
hendrixx324
thank you
if the fluid is allready visible when you open the cap would it still work the same way?
Old Aug 5, 2010 | 10:08 PM
Moneyman19's Avatar
Moneyman19
hey blown u and me both had the same problem.... but my heads were warped and both gaskets failed internally... warrenty had them milled... cant wait to hear her
