still trying to solve my rough idle
Over the past 2 days I have done the following:
replaced the plugs with autolight 3923's gapped to .040
took off the throttle body and cleaned it some (it didnt look that dirty)
just replaced the pcv valve but again the old one looked fine.
after doing all of this if anything the idle is the same or worse than before.
any other ideas?
any other ideas?
Ive reset it twice, once for the throttle body cleaning and the other for the plugs. I didnt reset it for the PCV though as I was told I shouldnt need to. If I should let me know and I'll reset it again.
I just picked up some Seafoam and will be doing a gas only treatment and see if that does anything.
hello
i was looking around the forum and i noticed this thread and i have the problem. The other day i went for a drive and i was stopped at a light and my truck my idling rough and then it decided to shut off.
so if you find any solutions i would be very thankfull.
good luck
good luck
Trending Topics
hello
good luck
good luck
