It's Alive!!!!!!!!
Old Aug 14, 2010 | 01:58 PM
WTEBOY703's Avatar
WTEBOY703
so what that'll give you what little bit more power over the stock TB? i mean i got mine from FASTMAN and it was just a true Bore to 68MM so its straight through 68MM not going down to 65MM in the back like a coke bottle effect my stock one had. He said 10WHP with that so i just went with it! Blown with the mods i have would going up to a 69 help out at all or should i just stick with what i got?
Old Aug 14, 2010 | 07:22 PM
Blown287's Avatar
Blown287
I would stick with the 68mm unless you go to a 72mm or something like that from F/B. 68-69mm would not be worth the $ to HP gain IMHO.
Old Aug 14, 2010 | 08:28 PM
trucky's Avatar
trucky
If you have a mild amount of mods a 72mm would be too big for you anyway. My pleasure to pass on the fastman Blown!
Old Aug 14, 2010 | 09:44 PM
Blown287's Avatar
Blown287
I will use it proudly, lol. Man did it feel good to drive the beast around today!
Old Aug 14, 2010 | 09:47 PM
trucky's Avatar
trucky
Originally Posted by ericemery
I dont know that it would be too much, I think you would just not be utilizing the extra porting. The engine can only pull in so much air.
Isn't that kind of the same thing I was saying? It wouldn't make performance any worse but not really better either... right? even if it did add a few horses it probably wouldn't be worth $200.
Old Aug 14, 2010 | 09:49 PM
Blown287's Avatar
Blown287
I dunno man, looking at $ vs HP..... I still say HO cams is the best bang for the buck.
Old Aug 14, 2010 | 09:56 PM
Blown287's Avatar
Blown287
Eric, this is my 1st performance throttle body so I will let you know how it works out for me. Today Travis and I boosted up to 8psi at 4,500 rpms several times without issue. Next week I will try a WOT and see if all holds like I think it will.
trucky's Avatar
trucky
I see what you are saying... I meant it would be too big for the amount of power difference he would be expecting.
