Rear Diff Fluid
Old Aug 15, 2010 | 09:14 PM
sullysdetailing's Avatar
sullysdetailing
Default Rear Diff Fluid
I am coming up to 30,000 miles and I am going to need to change my rear diff fluid. Is there anything else i need besides 4.5 pints of 75w140
Old Aug 15, 2010 | 09:16 PM
95_318SLT's Avatar
95_318SLT
Black RTV gasket maker and brake cleaner.
Old Aug 15, 2010 | 11:06 PM
rengnath's Avatar
rengnath
Maybe something to plug your nose ..... that fluid smells pretty bad, no joke.
Old Aug 15, 2010 | 11:31 PM
kingoftow's Avatar
kingoftow
Thumbs up diff fluid...
Greetings sullsdetailling, hey when you change that diff fluid make sure you add a small bottle of friction modifier(that is if you have a suregrip posi unit like my '98 Durango "loredda") otherwise you'll burn up the clutches in the unit...kingoftow
Old Aug 16, 2010 | 12:23 AM
Blown287's Avatar
Blown287
This is exactly what you need!
Some 4.10's
Master Install Kits
Limited Slip
Old Aug 16, 2010 | 04:06 PM
mprohr's Avatar
mprohr
I would recommend synthetic 75-140. More expensive, but worth it.
Old Aug 16, 2010 | 08:25 PM
damyankee84's Avatar
damyankee84
You also need one of these
http://www.drivetrainspecialists.com...hry-925-1.html
Old Aug 16, 2010 | 10:29 PM
JimBio's Avatar
JimBio
Felpro Gasket eliminates the rtv and the mess. $5 at most part stores
Old Aug 17, 2010 | 12:00 AM
sullysdetailing
I have the 8'' diff and a V6
So that cover will not work but i did find one that will.
Also i am going to be getting the AMSoil 75w-140
Old Aug 17, 2010 | 01:17 AM
italiandominator's Avatar
italiandominator
What kind of difference do 4.10 gears make over the stock 3.55 gears?
