would doing donuts mess my p/s pump??
I was doing donuts tonight then i suddenly had no steering. My pump was whinning like crazy. I am praying that it could be my pump and not my rack. Is it possible it could be my pump?
so....where you doing donuts on dry pavement, gravel or sand? Normally, at least in the old days of my camaro, you would do donuts by cranking the wheel to one side and flooring it....that never messed up any steering I had, but that was with recirculating ball steering (ala 73 Camaro and 74 El Camino).....never tried it with rack and pinion, but you should be able to do it the same way... crank the wheel and floor it, provided you have enough torque to break the rear end free...but my guess is you do with the SC...probably had more to do with centrifugal force throwing the fluid out of the pump/reservoir? Did the steering come back after you stopped doing donuts?
Check the fluid level. You could have tore a seal in the rack doing that. But my guess would be that you got a lot of air bubbles in the system and that it what is making the pump cry.
Ok so it wasnt wishfull thinking when i was tellin my friends that maybe itll be fine tomorow hahah.
Trending Topics
Guest
Posts: n/a
if you crank off your wheel for too long, you absolutely can have a trashed power steering pump.
donuts on dry pavement are probably not a good idea, unless you have a lot of power to slide the rear end around. if you have to keep the wheel cranked to get the turn, you probably dont have enough power. (think drifting, where you would need to counter-steer.)
