Fixing Front Bumper
Hey guys, I was just wondering if there was a way to "straighten" out my front bumper. It is a pushed up on the passenger side and is tight with the headlight and my foglight is also bent a little. Here is a pic, hope you can see it..
Should be as simple as loosening the 4 bolts by where the tow hooks would go and straightening it out. I have to believe they have some play in them. Mine is like this also. Will be trying to fix that this weekend.
That's what I thought, but my other ? is how do I fix the fog light? Once I drop the bumper it will cover most of the fog light right?
Trending Topics
Guest
Posts: n/a
well, no. but if your fog light is all jacked up, you will need to remove the fascia.
to adjust the fascia, your going to have to pull the fascia off and elongate the mounting holes in the wheel wells. from the factory, there are small round holes drilled, to adjust the fascia, you need to elongate those holes to allow for movement.
Normal gap...
after elongating the holes and adjusting the fascia.
Normal gap...
