No Cold AC?
Old Oct 11, 2010 | 02:29 PM
nola24's Avatar
nola24
Default No Cold AC?
I put in an efan last night, and today I go to turn the AC on, it blows, but when I hit the cold button, nothing! What gives?
I didn't mess with the AC, except to attempt to put the override for the fan with the AC clutch fuse. This did nothing so I put it back to normal though.
Old Oct 11, 2010 | 03:16 PM
is the compressor clutch engaging? fuse good?
Old Oct 11, 2010 | 07:49 PM
nola24's Avatar
nola24
I had my fan tied in to the HVAC fuse, and that was causing the problem. But now I don't know where to put the ignition tie in, especially since I don't think my temp probe is working.
Old Oct 11, 2010 | 08:31 PM
Ueland's Avatar
Ueland
I just did the same install...
Here's a direct link to how I have mine wired. it works perfectly.
https://dodgeforum.com/forum/2281669-post160.html
Also note that the A/C temp is partially controlled by the temp sensor mounted on the front frame (drivers side) in front of the radiator. It bases its temp off the actual outside temp, to prove this you can unplug the sensor and turn on the air and it will blow ICE cold... also note that doing this WILL THROW A CODE so be prepared to clear it if you try this out.
Also with the fan (green wire) hooked to the AC relay, it is only triggered when the compressor is actually engaged, not the entire time the AC is in operation. There's no problem with this configuration, just don't expect to test it and have the fan spring to life as soon as you hit the A/C button unless the a/c clutch is actually engaging.
Hope this helps....
Old Oct 11, 2010 | 09:17 PM
this may explain why my ac is not very cold sometimes? we need to come up with a "power wire" type mod so the thing makes the ac blow cold all the time!
Old Oct 11, 2010 | 09:24 PM
lmrjason's Avatar
lmrjason
a/c won't blow cold unless the fan is running...or your moving fast
Old Oct 11, 2010 | 09:33 PM
nola24's Avatar
nola24
Hope this helps....
Thanks a lot. So how did you actually connect the green wire to the fuse? Just jam the exposed wire under the fuse prong?
Old Oct 11, 2010 | 09:39 PM
Well, if you are referring to the HVAC fan, yes it is running.
or your moving fast
but i need cold air when I'm sitting in rush hour traffic and it's 99 degrees outside....lol
Old Oct 11, 2010 | 10:07 PM
Ueland's Avatar
Ueland
actually its a relay, and yes, I threw some solder on the end if the wire to make a tiny loop and put it through there...
I've got some fuse taps that work great, and I could probably send a few of those out if ya need em.
Old Oct 11, 2010 | 10:30 PM
nola24's Avatar
nola24
Well for the ignition wire I have a fuse tie in (same as tap?), so I think I'm good there, thanks. I just went out and rewired it, my fuse box is different from yours so I put the ignition wire in one of the spares, and put the override in with the AC Clutch relay. I started her up and turned the AC on.. nothing. But it shouldn't turn on till it's running for a while, right.. Guess I'll hope for the best tomorrow on my way to school.
