Sonnax Has arrived
#146
#147
Pardon me, that is the 2-3 shift, not the 1-2.
93 octane gas is over $3 a gallon again around here so I'm back to 87 tune. I'm happy with the sonnax, I really like the firmer shifts, does not lose as many RPM's. Between the sc holding it in gear longer and the sonnax providing firmer shifts, makes my truck a real screamer, really turns heads...lol
#149
Now that I think of it, Kent ...... when do you have your tuner set to shift at WOT? I would go back in there and see what your WOT setting is. If your Sonnax isnt letting you shift from 2-3, that means you may have to take it to about 90mph depending on how much the tuner is redlining the shift. I ride 2nd gear up to 5750RPM and that pushes me past 85mph.
#150
I have no idea, i just have the 87 performance tune installed. where would I go to find out the WOT setting and how do I change it? Maybe I need to monitor the RPM's, because I might be letting off before 5750. All I know is it gets there in a hurry and I'm usually like HOLY **** and let off because she's screaming like a bat out of h$ll and I dont want to blow it up! lol
