Help P0508 CODE
Old Oct 18, 2010 | 01:05 PM
Dpanther91303's Avatar
Dpanther91303
Default Help P0508 CODE
I have replaced the TPS, the IAC, the EGR. and the PCV. now im getting a P0508 code. Does anyone know the voltage of the connector to the IAC ?????
Any help will be great
Old Oct 18, 2010 | 01:56 PM
dakotajerry's Avatar
dakotajerry
Download the Service manual here first http://www.megaupload.com/?d=X8T6731C
Then go to page 9-493. It will give you a step by step on how to trouble shoot. and welcome to the forum.
Old Oct 18, 2010 | 02:12 PM
what are the symptoms? P0508 is usually caused by a vacuum leak resulting in a high idle so it throws the code saying the IAC is the problem because it can't control the idle. Have you checked for vacuum leaks?
Old Oct 18, 2010 | 02:56 PM
Dpanther91303
Symptoms are start then stop unless i detach hose from the PCV the it runs at a 10000 RPMs when i put the hose on it dies
Old Oct 18, 2010 | 03:36 PM
I hope you mean 1000 RPM's and not 10000 RPM's...lol...so you start it and it dies right away....unless you disconnect the PCV...then it will start but idles at 1000 RPM, and when you reconnect the PCV, it dies. Just trying to get the correct problem....
Old Oct 18, 2010 | 03:51 PM
Dpanther91303
yes sir
Old Oct 18, 2010 | 03:52 PM
Dpanther91303
thanx for the site its just what i was looking for
Old Oct 18, 2010 | 04:20 PM
dakotajerry
No problem, Now get some pics of that truck up. lol
Old Oct 18, 2010 | 05:28 PM
Dpanther91303
will do
