how does one remove the air intake resonator?
Old Oct 26, 2010 | 06:05 PM
mountainmike's Avatar
mountainmike
Default how does one remove the air intake resonator?
I see the 10mm bolt on the passenger side front. The this that is confusing me is the rubber plug-thingy that is on the front, on the drivers side...I can't seem to figure out how to get it to release.
I want the resonator out of the way so I can change out the copper plugs. Any help would kick ***.
Mike.
Old Oct 26, 2010 | 06:31 PM
Eimer123's Avatar
Eimer123
I will have pictures up for you in about 5 mins
Old Oct 26, 2010 | 06:46 PM
Eimer123's Avatar
Eimer123
I have mine removed but this should help
First you start out with your Intake
Then you loosen the hose clamps (5/16 nut driver or socket) on the flexible air tube that runs from the filter box to the intake box. Then remove the flexible tube.
Use a 10mm socket and remove the bolt on the front passenger side of the intake. Its right in front of the hose opening you just removed. The rubber grommet stays in place with the intake.
Then on the drivers side front of the air box there is a second bolt. Use 10mm socket and remove the bolt. Rubber grommet stays in place with the intake.
Remove the air temp sensor. It is held in my a O-ring. Do not drop or bang this piece.
the sensor looks like this minus the wires being cut. (WARNING: DO NOT CUT THE WIRES TO REMOVE)
Its location is here in that 1/2" hole
Then all you need to do is slide the intake off of the throttle body.
Old Oct 26, 2010 | 06:48 PM
rengnath's Avatar
rengnath
The resonator is held the the throttle body with a clamp. Youll need a pliers to release it.
Old Oct 26, 2010 | 07:45 PM
mountainmike
Thanks for the pictures but that's different than mine. I have on '08 with the new 4.7l and there is no second 10mm bolt on the passenger side. Instead there is a rubber grommet looking piece that I am afraid of breaking.
Old Oct 26, 2010 | 07:54 PM
can you take a picture so we know what your talking about?
Old Oct 26, 2010 | 10:58 PM
WTEBOY703's Avatar
WTEBOY703
yeah second on that i wanna see what your talking about!
Old Oct 26, 2010 | 11:15 PM
Eimer123's Avatar
Eimer123
Ahh yea the 08 is different, Fill out your vehicle info tag in the "User CP"
Old Oct 26, 2010 | 11:18 PM
this is what an 08 looks like but I can't see what he's talking about in this angle.
Old Oct 26, 2010 | 11:23 PM
Eimer123's Avatar
Eimer123
Does this help?
http://www.carid.com/images/air-inta...-1558_inst.pdf
