Turbo Kit
Old Oct 27, 2010 | 10:12 PM
aartzer's Avatar
aartzer
Default Turbo Kit
Hey just tossing an idea around and wanting to know the pros and ons and some extra info. I have an 06 SLT v8 and I was thinking about getting the universal sts turbo kit and mounting the turbo in front of the rear tire and having a side exit exhaust. Does anyone know the max horsepower the standard 4.7 can handle and what would be other problem areas that anyone knows of when using a power adder.
Old Oct 27, 2010 | 11:36 PM
ruger226's Avatar
ruger226
Blown287 has ran 14psi without blowing it up but he has ALOT of work done to suppert it. With a stock motor and a sts kit i personally wouldent run more than 8-10 psi. And as for max hp (correct me if im wrong) i dont think anyone really knows at this point.
Old Oct 28, 2010 | 04:31 PM
ruger226's Avatar
ruger226
STS claims that you will make more hp with stock exhaust manifolds. So i wouldent worry about headers.
Old Oct 28, 2010 | 05:55 PM
dakotajerry's Avatar
dakotajerry
Yes the STS turbo performs better with stock exhaust manifolds because they retain the heat. Header loose to much heat for the turbo. Most of the guys that put header had to end up wrapping them because of heat lost.
Old Oct 29, 2010 | 08:28 PM
Blown287's Avatar
Blown287
Originally Posted by ericemery
Blown, that is what your grind is specified as right?
Yes, mine is a Watson Performance 224 turbo grind cam.
Old Nov 1, 2010 | 02:09 AM
aartzer's Avatar
aartzer
Whats the Watson Route?
Old Nov 1, 2010 | 02:20 AM
Blown287's Avatar
Blown287
Watson Performance
The problems I've had with boost.
#1 Motor Mounts. Vulcanized Rubber will not hold a high HP engine. I've broken two sets of stock motor mounts.
#2 Blown Head Gasket. No bid deal, changed it out in my Garage.
Other than that, I haven't had any trouble. On the flip side, I know of 6 boosted 4.7Ls and five of them have issues.
