exhaust question
Old Nov 10, 2010 | 09:51 PM
06firedak's Avatar
06firedak
Default exhaust question
Im running an 06 4.7 with stock exhaust, my question is since I put on my CAI its seems as if I am choking my engine. My exhaust has the standard cat on each down tube, then a resanator then muffler then another resanator. Is it possible that the engine is pulling more air in than it can get rid of through the restrictions of the exhaust. I plan on upgrading the exhaust when the money comes available but til then should i remove the CAI. Any and all thoughts welcome
Old Nov 10, 2010 | 09:58 PM
Pwall's Avatar
Pwall
yes you can be choking the engine it needs to be able to expel as much air as it brings in
Old Nov 11, 2010 | 12:21 AM
WTEBOY703's Avatar
WTEBOY703
OMG no you are not choking the engine! if you were do you think almost everyone would have one? what makes you hink your choking the engine? no keep it on you'll be fine!
Old Nov 11, 2010 | 04:01 AM
gjmoran's Avatar
gjmoran
i know exactly what you are talking about, i also run stock exhaust and it seems like after installing the cai it is robbing my truck of power. but i like the way it sounds so i keep it on
Old Nov 11, 2010 | 04:51 AM
Backwoods18's Avatar
Backwoods18
You're not choking your engine. The engine can only suck in as much air as it can get out. Other words, it only takes in as much as it needs. Once you upgrade your exhaust and allow more air to flow through your motor, your engine will just suck in more air. Did I explain that good enough? (I suck at explaining stuff)
Old Nov 11, 2010 | 08:31 AM
Hammond_Egger's Avatar
Hammond_Egger
Question: Did you disconnect your battery since you installed your CAI? (leave it disconnected for an hour or overnight)
Might be a good idea to have your engine "relearn" since putting in your CAI.
Not saying this will fix your issue, but might help!
Old Nov 11, 2010 | 08:45 AM
WTEBOY703's Avatar
WTEBOY703
yeah...cause if you were just choking it with an intake...then what about vehicles that are boosted (turbos/superchargers) dont ya think those would choke? lol sorry not meaning to sound like an *** but PWALL just made the stupidest remark and i was like GET THE HECK OUTA DODGE
