Need help asap!!!!
Old Nov 13, 2010 | 10:28 PM
hendrixx324's Avatar
hendrixx324
Originally Posted by jkeaton
That sucks, I wonder if it's your huge tires causing the front end problems?
I dont think so bacause there are plenty of people on here with bigger tires on there DAK
Old Nov 13, 2010 | 11:42 PM
WTEBOY703's Avatar
WTEBOY703
yeah...so the front diff is movng even when not in 4X4? wouldn't that make the front wheel move? just crurios
Old Nov 14, 2010 | 12:01 AM
hendrixx324
The front wheels move when you roll. So that spins the CV shafts witch then spins the gears in the diff witch spins the drive shaft. The drivshaft is disengaged from the transfercase.
Old Nov 14, 2010 | 11:19 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by Blown287
Wow, that sucks man. You are the second person I know thats grenaded the front transfer case.
Same here
Originally Posted by rengnath
Was Dusty the first one? He was launching his Dak in 4wd with a Hemi at the strip. Its wierd that this time it just happened out of no where while not even being in 4wd.
I dont believe it was Dusty. I am pretty sure he was using 4wd, offroading. It cracked the entire housing though.
