HHR Fan Connector
Old Nov 15, 2010 | 08:37 PM
Blown287's Avatar
Blown287
Default HHR Fan Connector
A while back I was asked if it were possible to make a wiring harness for the HHR fan vice using universal connectors and making a jumper. I finally got around to it so here it is.
AC Delco HHR Fan Connector PT189 / 12101917
6.3mm 2 way pin "T" Multi Connector
I connected the 6.3mm connectors and heat shrunk them.
I chose a black "T" vice the clear. The connectors snap in place inside the T.
The finished product and works great.
[IMG]http://i253.photobucket.com/albums/hh73/squidbill/T011.jpg[/IMG
Installed
Old Nov 15, 2010 | 10:12 PM
hendrixx324's Avatar
hendrixx324
nice il have to make one of them.
Old Nov 16, 2010 | 01:14 AM
gjmoran's Avatar
gjmoran
looks really good
Old Nov 16, 2010 | 02:27 AM
Blown287's Avatar
Blown287
Thank you gentlemen. The "T" I chose is the same type that comes with the
SPAL (female tip). The male is the same as what is found on a lot of universal fans such as the Proform. However, you can match the connector to what ever type of fan controller you use.
Old Nov 16, 2010 | 08:24 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Go ahead and put me down for one.
Old Nov 17, 2010 | 01:38 AM
Blown287's Avatar
Blown287
Tomorrow I will try and take a picture of it installed. Looks factory.
Old Nov 17, 2010 | 04:39 AM
WTEBOY703's Avatar
WTEBOY703
nice...nothing blown can't fix or FAB up
WTEBOY703's Avatar
WTEBOY703
oh BTW did you ever finish those mounting backets for the FAN?
Old Nov 17, 2010 | 09:36 AM
donkeypunch
King Jackass
Where did you find the 6.3m connector?
Old Nov 17, 2010 | 04:40 PM
Blown287's Avatar
Blown287
I ordered them from here.
http://www.kojaycat.com/connectors.htm
Also I updated to the OP and added pictures of it installed.
