inner fender removal and install
how hard is it to install the driver side inner fender,what all do i take off,all i see is 2 or 3 screws that holds it onto the fender and a few tree push pins behind the tire.any tips would be helpful,thanks
you have to take a couple screws out and remove several of these little metal clips that look like giant pop rivets, which will probably break. and you have to take a couple of these pop rivet things out of the little mud flap piece too.
Trending Topics
The inner plastic fender well... I just did that one a few weeks ago. Removal is easy, installation.. that's another story...
There's 11 "POM" rivets that hold it on. to remove the plastic rivets you just push in on the centers and they release. WARNING: they are not reusable!!! You will need to purchase more rivets to replace them. They operate just like standard rivets and snap off the stems upon installation.
Good news is that I've already done the legwork in finding the rivets and the tool for cheap. Here's what you will need.
Harbor freight sells it for $15 bucks. (everyone else sells it for $40)
http://www.harborfreight.com/hand-ri...ets-97757.html
You can get by with the rivets that are in the kit but if you want some extras they sell em there too...
http://www.harborfreight.com/catalog...ategory=&q=pom
Just bring in one of yours to match up the size
One more note on installation, grab a nail punch or something in case you need to ream out the holes and help line them up upon installation. Also the "factory tool" snaps them off clean, where you may have to go behind the harbor freight tool with a razor or a pair of dikes to remove the excess sticking out (usually like 1/4-18 inch)
