05-07 NAV radio bezel
Old 11-26-2010, 07:36 PM
SLT07Dakota's Avatar
SLT07Dakota
SLT07Dakota is offline
Default 05-07 NAV radio bezel
Did they put the NAV decks in the 05-07 Daks?
I may have of just got my hands on a NAV deck from a Commander and need to know where and if I can find a bezel for it.
Thanks Mark
Old 11-26-2010, 07:55 PM
dodgetrucker75's Avatar
dodgetrucker75
dodgetrucker75 is offline
you need one from an 08 or newer, you will also need some sort of an adapter for the 05-07's but i think the lock pick covers that too
Old 11-26-2010, 08:07 PM
SLT07Dakota
The whole bezel is different from 07 to 08 are they not??
My dash looks different then a 08 ??
Thanks Mark
Old 11-26-2010, 08:17 PM
dodgetrucker75
they are the same, just a different radio cutout
Old 11-26-2010, 10:42 PM
rengnath's Avatar
rengnath
rengnath is offline
You may want to try removing the bezel and trying to install the radio in the dash. If it will bolt up (most likely it will since a mygig will fit) then all you need to do is trim your current bezel.
Old 11-26-2010, 11:32 PM
WTEBOY703's Avatar
WTEBOY703
WTEBOY703 is offline
same...but some trimming may be required!
Old 11-26-2010, 11:43 PM
Hammond_Egger's Avatar
Hammond_Egger
Hammond_Egger is offline
Wrong! They are not the same at all. I have a 2005, and have added a Mygig with NAV (RER).
You need to trim out the opening of the bezel, radio mounts fine in the dash.
Here is a (crude) pic of mine:
Old 12-03-2010, 07:49 PM
SLT07Dakota
WOW, I had a lot of reading to do, been off line for a bit.
Thanks Hammond for the pic!
So I guess you need to flaten out the sides of the bezel or the whole thing is bigger?
I believe the radio I am getting is the same (or so it looks close)
Is the radio plug in the back different ?
One more dumb question, I dont have the radio home yet but how do you load a CD??
Thanks Mark
Old 12-03-2010, 09:00 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
The screen moves out of the way when you hit the open/close button and you insert the CD near the top.
Old 12-03-2010, 09:03 PM
SLT07Dakota
Thanks buddy !
Quick Reply: 05-07 NAV radio bezel
