CAI????body lift???options???
Old Jan 2, 2011 | 09:05 PM
Dakkkota's Avatar
Dakkkota
Default CAI????body lift???options???
what intake should fit good with body lifted???
Old Jan 2, 2011 | 09:16 PM
rengnath's Avatar
rengnath
You may be best off doing an ebay intake or making one yourself. Any ones that I have seen that are name brand are going to need the wheel wells to bolt to.
Do you have the stock air box and intake still? How is that working with the body lift?
Old Jan 2, 2011 | 09:29 PM
Dakkkota's Avatar
Dakkkota
nope...i have the stock air silencer box and the filter box removed...installed a plumbing rubber union 3,5 to a exhaust pipe to a k&n filter at stock location of the box...hope i can suck some cold air now
Old Jan 2, 2011 | 09:43 PM
rengnath's Avatar
rengnath
Yeah, nothing is going to work unless you mod it. You can get the Airaid CAI without the tube for about $150. Then, run ABS to the throttle body. The Airaid CAI that doesnt have the tube uses the stock air box though. I believe its called the "QuickFit"
Old Jan 3, 2011 | 01:09 AM
WTEBOY703's Avatar
WTEBOY703
Old Jan 3, 2011 | 12:16 PM
rengnath's Avatar
rengnath
My bad, I always forget. Heres a pick of the "Quickfit"
The Airaid Modular Intake tube can be purchased seperatly for about $100, but in Dakkkota's case, I would just run some 3 inch pipe to the throttle body.
Old Jan 3, 2011 | 12:23 PM
WTEBOY703's Avatar
WTEBOY703
not bad not bad at all! good stuff man!
Old Jan 3, 2011 | 01:04 PM
so that airraid thing sits on top of the stock box and is sealed to the hood?
Old Jan 3, 2011 | 01:10 PM
rengnath's Avatar
rengnath
Yup, it sits on top of the box, and then has a shield that goes to the hood. Its not a really tight seal because air can get in from the side by the fender. But by using the stock box, it made it alot easier to route my bumper scoop.
Old Jan 3, 2011 | 09:07 PM
WTEBOY703's Avatar
WTEBOY703
well good stuff man looks good and functional! i say HOOAH
