fog light bulb question 9145 or 9005???
Old Feb 26, 2011 | 09:25 PM
  #51
Ueland's Avatar
Ueland
Originally Posted by rengnath
Reason #1 to not use 9005's in factory housings...
...I couldnt figure out where the burning plastic smell was coming from ..... until I remembered the fog lights.
Damn.. So if you were smelling the plastic, does that mean you were parked with them on for a while? or were you moving??
Old Feb 26, 2011 | 10:38 PM
  #52
rengnath's Avatar
rengnath
Combo of both. Funny thing is I would smell the burning plastic right at start up with the heat running. I kept thinking it was something with my heater core. The smell was pretty faint at first, and almost lead me to believe I was smelling antifreeze. When I popped the hood, I could only smell it in certain places. If I turned off the heat in the cab, I never got any odor inside.
Today, I smelt it when I got out of the truck from coming home from work. Went to go drop something off by my sister, and came back in to the truck that I left running and it was a strong smell of burning plastic. Then I remembered the fogs, so I turned them off and didnt get any odor at all. Examined the driver side first and swapped the bulb back to stock and found nothing wrong. Went to the passanger side and saw the bulb sitting on its side melted throught the housing. FML.
I checked the fog lights several times after driving. The lense was always cool to the touch, and they were today as well. It only melted the holder that the light locks in to, and that casued the bulb to fall on the side of the housing.
Oh well, TIME TO UPGRADE
And I say it is not safe to run 9005s in factory fogs regardless of how fast you are moving. Aftermarket fogs seem to hold up better to the heat.
Old Feb 26, 2011 | 11:04 PM
  #53
I just took mine out tonight for inspection. all systems normal. I've been running them for about 3 weeks now....maybe its those chinese brand fog light housings I got from rock auto...lol
Old Feb 26, 2011 | 11:07 PM
  #54
rengnath's Avatar
rengnath
Yeah, Eric commented that the factories just cant handle the heat. The point of failure is small on the factories. The actual housing can handle the heat .... until the bulb holder melts and the bulb tilts.
Old Feb 27, 2011 | 12:49 AM
  #55
cheeseburger's Avatar
cheeseburger
oh... dude... i guess i need to look at mine a little closer....
Old Feb 27, 2011 | 01:05 AM
  #56
rengnath's Avatar
rengnath
You dont have OEM ones though do you Cheese? If you dont, I wouldnt worry too much ..... unless you are smelling something burning. Lol
Old Feb 27, 2011 | 05:11 PM
  #57
Dinger838's Avatar
Dinger838
The bulb holder melted on me too
Old Feb 27, 2011 | 06:34 PM
  #58
i dont understand the melting. whats the difference between the 9005 and 9145 besides the painted tip and 10 watts? 10 watts makes that much heat difference?
Old Feb 27, 2011 | 10:46 PM
  #59
Ueland's Avatar
Ueland
painted tip would actually make the bulb run a bit hotter, and the unpainted would make the center of the lens heat up.
I'm kinda wondering if the mounting tabs aren't 100% (or even if they are) is there a chance Those guys didn't get them fully locked in and they bounced free letting the light burn the housing?
Old Feb 28, 2011 | 02:22 AM
  #60
cheeseburger
just checked mine again tonight and still not even a little melting... i studied both of them very carefully and not even a little dark spot. the holder is good. and i dont know if this would make a difference or not but since i had to "make" these work i am using the original wiring harness's for these bulbs.
