Billet Impeller
Check this out guys, I might get this done also. There is a billet impeller from my blower, once its swapped for the Paxton Impeller my blower will be capable of 26psi. It will be like having a Novi2000 at 1/4 the price.
Check it out.
http://www.928motorsports.com/parts/paxton_impeller.php
Check it out.
I wish my truck had the stuff to make one of those work. Lol.
When I hear 1/4th the price though, my eyes light up! When are you doing the aluminum intake so you can up the boost and not blow up the manifold?
A new Novi2000 head unit cost over $2,000. I can get the same output with my Novi1000 for $504. That includes shipping both ways, impeller and install. I will also need one of these, lol, like we installed on Travis's.
For the aluminum intake, I don't know yet. There is a chance the Victor Jr. won't work as its for the 2 valve setup and the Airram adapter are for the 3 valve. I'm still thinking of trying to make it work anyway, lol.
Mod list for spring now inlcude.
Auburn LSD w 3.55's install
Water to air intercooler
Sharadon Stage-3 tranny valve body
Billet Impeller
Boost limiter
That will probably be all until after I finish school in Rhode Island.
Billet Impeller
Boost limiter
Blown, I like it. Most of us DSM guys are tickled about the billet compressor wheels that Garrett is offering now ( better spool time, better midrange, and a crap load more top end).
As far as the intercooler setup goes, air-to-water setups are a pain to deal with. I absolutely hated crew chiefing one of my buddy's cars. Plus, you are taxing your charging system with the water pump, and your meth injection pump.
If I was in your shoes, I would stick with air-to-air. If you are worried about heat soaking the intercooler, do what I do. Get a nitrous intercooler sprayer, and use CO2. You will get higher hp and torgue, reduce pre-detonation, and no tax your charging system even further. Just my 2 cents.
Love the setup though, I think those 3.55's are going to keep the load on the engine and let it do what it wants. In the race car, the stock gear ratio is 3.55 as a final drive. However, my 1st gear ratio is way too short. I only build about 5psi in 1st gear (severe tire spin), 13psi in 2nd (still severe spin) and then hit 25psi for 3rd (tire scrubs hard until about 70mph) and 4th. By the way, by next summer, I might not be fwd anymore. All I'm going to say right now, is that I'm purchasing a ford 8.8"...
Trending Topics
