Bazooka Bass Tube installed
There was a thread about the Bazooka Tubes a while ago, as well as questions about subs. I had the Bazooka Tube, model # BTA8250D, installed a few weeks ago and the sound is AMAZING! There is incredible bass with this tube, it sounds like I put a ton of money into my system, but not really.
If you're looking to add some kick-*** bass, this is a simple solution. The amplifier is inside the tube, and the whole tube simply disconnects with 2 plugs to remove it for the extra room. These tubes come in 6", 8", and 10" tubes, the 8" model that I have fits behind the seat perfectly. I found the best prices on Amazon, $220 for the 8" model.
8" link
8" link
I had it installed, I didn't have the time to really get into it, and I wanted it in already. But check out page 7 (that A200 connections) on this link, it's only really a few connections.
http://www.bazooka.com/pdf/current/T...gualforweb.pdf
And there is a Bazooka forum, just sign up and post up any questions in the Amplified Tube Subwoofers Section. 'Heavyduty' will answer all of your questions pretty quickly.
Bazooka Forum
http://www.bazooka.com/forums/index.php
With this tube, you can really feel the bass, it really is awesome!
Bazooka Forum
1 wire to power.
1 wire to ground.
1 wire to remote out from radio.
And then wires to both channels of speakers.
It turns on with the radio.
That looks awesome!
I used to have Bazooka Bass tubes, they were the first generation back in the '80s when they came out.
They made a lot of bass. And i had the 2 bass tubes 10 inches each on the back of a '83 Mazda RX7.
I remember i paid about $250.00 for each of the tubes!
Wow, good times !!!!
Trending Topics
That looks awesome!
