Someone built a custom drop diff???
Old Jan 24, 2011 | 04:59 AM
Backwoods18's Avatar
Backwoods18
Originally Posted by Desert_Rat
Sounds like it might work. I've recently started to try to figure out a front suspension lift and was either thinking of making a 2nd gen kit work or modifying pieces from a tacoma kit. Do the 2nd gen upper arms leveling kit allow the steering knuckle to sit lower and maintain the ball joint angle?
I'm new to this site and haven't worked too much on the suspension so correct me if I'm wrong:
For a front suspension lift, all I need to do is
-drop the lower control arms (using a drop bracket)
-drop the differential (and correct the cv angle)
-either extend the steering knuckle to be taller OR drop/lower the upper control arms
-replace coil over with a longer coil over OR drop the upper mount for the coil over (preferably replace the coil over to allow for more travel)
Like I said, I'm new to this so go easy on me if I messed something up!
You have just about everything figured out. lol
Old Jan 24, 2011 | 03:57 PM
Dakkkota's Avatar
Dakkkota
Default hey???
the lower control arms seem and lower ball joints seem pretty tuff and can handle extreme angle (like chasis teck kit) well the only problem is the upper control arms that the extreme angle due to a leveling kit destroy the ball joint...why nobody tried a spacer between control arm and ball joint??
Old Jan 24, 2011 | 04:19 PM
Desert_Rat's Avatar
Desert_Rat
That's what I'm thnking...it doesn't seem too hard to make a spacer that sits under the ball joint (would attach to the top of the steering knuckle). The hardest part would then be dropping the transfer case (or diff...not quite sure) so that the axle would not have an extreme angle. If that's dropped the lowe contol arms might need to be dropped just cuz they will get inthe way of the axle, depending onthe amount of lift desired ( I'm wanting 6")
Old Jan 24, 2011 | 04:54 PM
Dakkkota's Avatar
Dakkkota
Default good to have one person more in the project
just depend on your tooling and skills im curious to see...
well what you can do is take 2 leveling kit at the same time tm(inside strut) and daystar stile(over strut) combinated, flip tie rod , use drop diff kit from rancho 2nd gen kit, a spacer between balljoint and control arm and exhaust will need a little modification to drop diff.
that is my futur project...and for the rear i have 1,5 block and im gonna go with 2500 ram leafs
Old Jan 24, 2011 | 08:55 PM
Desert_Rat's Avatar
Desert_Rat
Default ok, ok
looked at it again today after school and i think we have a pretty good plan. For the steering kuckle/upper ball joint spacer, here's what I'm thinking:
Drill out the original hole on the steering knuckle that the ball joint goes into (if i remember correctly, this is normally tapered. Then, find thick walled steel pipe (about 2 inches OD) and on the bottom end, cap it off with probably 1/4 inch thick plate steel and drill a hole in the center the same size as the newly drilled hole in the steering knuckle. Weld this cap onto the pipe. Now, find/get 2 (1 for drivers side and 1 for pas side) old steering knuckles from a junk yard and cut off the ends (the same piece that we drilled out earlier). This piece is already a cylinder about 2 inches OD and 3/4 inch tall. This will be welded onto the top of the pipe. Now, extend the ball joint bolt. This can either be done by finding a prefabricated bolt extension (which is probably hard to find in the same threading), or by getting a long grade 8 bolt, cutting it to desired length, and welding the two bolts together end to end by slipping a small pipe that will join the two (this way you don't have to worry about the bolts staying inline when welding).
I will put up some pics in a second...trying to figure out how to get them from facebook to here
Old Jan 24, 2011 | 08:59 PM
Dakkkota's Avatar
Dakkkota
Default add me on facebook
Mathieu Synnott
Old Jan 26, 2011 | 12:53 AM
Desert_Rat's Avatar
Desert_Rat
Default like this...
sorry the pic took so long. It took me a little while to figure out how to post pics...haha I can fab up parts on my spare time in nursing school but can't work a forum! lol
Old Jan 26, 2011 | 05:15 AM
projektdirtfab's Avatar
projektdirtfab
oh boy! thats gunna call for some serious negative camber issues
Old Jan 26, 2011 | 06:43 PM
studlyblueiz's Avatar
studlyblueiz
Plus I don't think welding to a cast knuckle will work out very well
Old Jan 26, 2011 | 06:46 PM
Dakkkota's Avatar
Dakkkota
dont like it safety first!!!
