Body Lift Question.
Old Jan 24, 2011 | 04:48 PM
Backwoods18's Avatar
Backwoods18
Default Body Lift Question.
I am going to attempt to make my own body lift. ( Not out of hockey puck, I know better!) http://www.usplastic.com/catalog/ite...ickid=redirect, that is what I am using. My question is how high can I go before I need steering extensions, etc. and what diameter should I order?
Edit: Also any info on bolts and sizes, as well as how many body mounts we have would be awesome! TIA, Nick
Old Jan 24, 2011 | 05:08 PM
Dakkkota's Avatar
Dakkkota
after performing alot of bodylift kit on many truck you have the expensive way 460$ performance accessories with bracket for bumpers ans stering extension for 3 inches,with perfect look and easyest. someone here did one him self 2" stock stering coupler. but if you want to go wilder than 3" (4-5)i suggest you square tubing and using 2 bolt (stock one) + a new one under you will have WAY less flex while offraoding (my friend P.A. bodilift on his bronco bent all screws the truck looks all wrapped
http://www.astrosafari.com/viewtopic...=9687&start=10
Backwoods18
I want to build it myself. So two inch max with out any modding to steering coupler and radiator, funds are really limited and I have a week off of work so I am looking for something to do and hey, why the hell not? lol. More opinions would be nice. (nothing against you dakkkota but it is my saftey and truck on the line lol) Thanks.
Old Jan 24, 2011 | 05:12 PM
Dakkkota's Avatar
Dakkkota
for the box mesure from one side to the other so box sits on the square tubbing from left to right
for 2 inches your idea is good!!! nothing against you!!!
im curious to se some one with a 4'' bodylift!!!
Old Jan 24, 2011 | 05:18 PM
Backwoods18
Haha, I didn't take a offense to anything buddy.
That would be cool!!!!!!!
Old Jan 24, 2011 | 05:47 PM
donkeypunch's Avatar
donkeypunch
King Jackass
The only problem I see with cutting your own sticks of material is insuring the same height of all peices. I suppose if you had a lathe, you might be ok. Hockey pucks really aren't that bad of an idea (been used forever by ranchers, and are all the same height).
Old Jan 24, 2011 | 05:50 PM
Backwoods18
I have seen lots of hockey pucks deteriorate and fall apart in colder weather. I already have it figured out, just need to know how high I can go with out changing linkage's and how many mounts we have and bolt information, (length, diameter etc..)
Old Jan 24, 2011 | 06:08 PM
ruger226's Avatar
ruger226
Hey man i hope you have a heated garage or shop because its effin cold in rochester and im sure its just as bad in oswego.
Old Jan 24, 2011 | 06:11 PM
Backwoods18
Haha, waiting until tomorrow to crawl under the truck and do some R&D, I will start with the bed portion when I do it. Man, I am so excited. I am either running with the plastic material or washers and pipe, not sure yet. lol
Old Jan 24, 2011 | 06:25 PM
Washers and pipe?? Like galvanized water pipe or something?
