max tire size for stock 08
Old Feb 3, 2011 | 12:34 AM
canukdakota's Avatar
canukdakota
Default max tire size for stock 08
i was wondering how big i could go at stock height i have 245/70r16 on it stock i want to go 245/75r16 for winter mayb a little bigger for the summer
if they arnt going to fit i do plan on getting the 2' leveling kit in the front mayb add a leaf to the back (the spacer that makes the spring stiffer)
dont want go offroad to much but i do in hunting season and there are a few trails around were i need a little more height
do not want anyrub or triming (a little rub wile flexing will be ok)
Old Feb 3, 2011 | 12:16 PM
dakota_raven's Avatar
dakota_raven
Second post!! Welcome to the forum.
Couple of questions:
Is your Dak 4x4? Mine is 4x4 with the TRX4 package and came factory with 265/70/16 . That is almost a 31 inch tire. With the leveling kit on a 4x4 you could go up to 32 inches and up to 33 inches with a little trimming here and there...
I went with 18 inch wheels and a 31 inch tire and got no rub but like i said mine is 4x4 TRX4... You can see it in my photo album on my profile..
Good luck with your choice!!!
And by the way , post some pics!!
Old Feb 3, 2011 | 12:48 PM
Cavi's Avatar
Cavi
by going from the 70 profile to the 75 profile you are going from a 30 inch tire to a 30.5, that should fit no problem at all. I would imagine that a 31 inch tire would fit with no issues.
Old Feb 3, 2011 | 01:19 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
You could fit a 245/75 R16, or a 265/70 R16. Some have been able to squeeze in a 265/75 R16 (I used to run that size with no lift) but it is hit or miss if it will rub or not. Plus, it looks too big IMO.
245/75R16 or 265/70R16.
Because 265/70 R16 is a factory size, you can go right to dodge and they will happily reprogram your ECU to correct your speedo/odo with the new size. I think they did it for $20 when I went. It literally took 2 minutes.
Old Feb 5, 2011 | 01:17 PM
canukdakota
yes it is 4/4
pics comin soon been busy at work this week and its dark shortly after i get home
does anyone have measurements from the trail master lift kit that adds preload to the spring looks realy easy to make (i have realy easy acces to a machine shop were they have small peices of steel around that size) just askin because i usualy to get parts shipped up here costs more than the part itself and i havent been able to get to napa to see if they could get it or not and to try a diferent supplyer is an 8 hour drive away (i kinda live in the middle of nowere)
Old Feb 5, 2011 | 04:52 PM
got2go4x4's Avatar
got2go4x4
I have an 08 4x4 I am running 245/70/r16 AT grabbers with after market rims. I tried to put 265 but they would have rubbed really bad because of the off set of the after market rims, i think with the leveling kit the 265 would have fit but not 100% sure.
Old Feb 5, 2011 | 05:08 PM
rengnath's Avatar
rengnath
Sorry canuk, I wouldve measured mine but they were installed on Tuesday. I know 3/4" will give you 1.5" of lift. Not sure about the diameter or anything though.
265/70/16 is an awesome size tire, IMO. Its what I have on my truck and they just look so much better than the 245/70/16s, and they wont slow you down too much. They are 1 inch taller and 1 inch wider.
Old Feb 5, 2011 | 08:41 PM
Cavi's Avatar
Cavi
did you loose any MPG when going from the 245/70/16 to the 265/70/16 ?
Old Feb 5, 2011 | 09:08 PM
rengnath's Avatar
rengnath
Im sure I did. I went from Firestone Destination A/Ts to BFG A/Ts which is a much heavier tire, along with it being taller/wider. Not sure how much I lost though, I dont keep track. When the needle is low, I fill it up.
Old Feb 6, 2011 | 11:28 AM
Racinartist's Avatar
Racinartist
According to my calculations, a 70 is 30.5 and a 75 is 31.5 (approximately).
