Lift kit already here!?!?!?!?!?
Old Feb 17, 2011 | 08:39 AM
  #41
donkeypunch's Avatar
donkeypunch
King Jackass
This does seem a little fishy. Well, I suppose that we can continue to wait for any type of photographic evidence of existence.
I feel like I have to go to a shrink to get myself over exiting new parts for our trucks. It seems as though I got the short end of the stick when I bought my brand new truck. Don't get me wrong, I love my Dak. But there is nothing out for the 3.7L that goes beyond 3 mods, two companies that make aftermarket struts and shocks, we can only install a body lift to get 3" of lift...and a 2" leveling kit in the front.
I've been thinking about it for a long time, and I think I see a 2011-2012 Power Wagon in my future.
Old May 22, 2011 | 05:14 PM
  #42
mauricio4x4's Avatar
mauricio4x4
does anyone saw this kit?
its really a lift for dakotas 2010??
http://www.airbagit.com/product-p/x2-kit4-dk05xx.htm
Old May 22, 2011 | 05:43 PM
  #43
Read the thread... airbagit is bad news
Old May 23, 2011 | 09:15 AM
  #44
dakota_raven's Avatar
dakota_raven
Old May 23, 2011 | 03:14 PM
  #45
projektdirtfab's Avatar
projektdirtfab
i think we need to make a "lift kit 101" thread. too many new comers (no offense) asking the same questions. if we had one compiled thread of info about all the different companies and future developments, they could just read that one thread.
Old May 23, 2011 | 03:22 PM
  #46
cheeseburger's Avatar
cheeseburger
THIS!!!!
Old May 23, 2011 | 03:38 PM
  #47
dakota_raven
Old May 23, 2011 | 04:31 PM
  #48
Brand's Avatar
Brand
Sure.
Those of us who do search for stuff before asking often find missing images & broken links & stuff.
Case in point:
2-inch Above-Strut Lift Install DIY
Should we start an outline or list of topics that a "Gen3 Lift FAQ" ought to include?
  • Above-strut vs. "intra-strut" options (which vendors offer what, pros and cons of each, how to choose, how to install)
  • Rear lift blocks (Vendors, preferred materials, when to use, tapered or not, impact on other suspension mods like air bags)
  • Air Bags (Air Lift vs. Firestone, others, combining with add-a-leaf/helper spring or blocks)
  • How much lift required for which size tires, other issues (trimming, CV and U-joint longevity)
  • Makes and model #'s of stock (and longer-than-stock) rear shocks
How's that for a start?
Old May 23, 2011 | 05:17 PM
  #49
Originally Posted by Brand
Sure.
Case in point:
I agree! Cody would be a good resource for this info, imo. Of course there are probably others, but he came to mind first since he is working on the suspension stuff now....
Old May 23, 2011 | 05:18 PM
  #50
Brand's Avatar
Brand
Here's some of what I've learned recently:
Air Lift brand "Ride Control" airbag kit is #59555. MSRP is $326. The going street price as of 5/2011 is $215-250.
Installation instructions PDF
Air bags should NOT be relied upon to achieve static, all-the-time lift. Get your truck level and at the desired height by other means first. Air bags will RESTORE that desired static ride height (whatever it ends up being) when the truck sags or squats under a temporary increased load, like towing a trailer or hauling a camper.
The Air-Lift kit installs between the leaf spring and the truck frame. That dimension is unaffected by the use of lift blocks, so no adjustment to the air bag mounting brackets should be required. The use of "helper springs" (aka "Add-a-Leafs") or custom/re-arched/swapped leaf springs WILL change the spring-to-frame dimension, and bracketry modification WILL therefore be required.
(I'm not familiar with the Firestone option, how and where it installs, etc.)
Daystar 2-inch Above-Strut Spacer Kit is part #KC09107BK. Street price on this kit as of 5/2011 is $120-150. Many pages and vendors state that this kit is for 2006-2011 Dakota, but the Installation instruction PDF indicates that it will fit 2005 as well.
This spacer is made of polyurethane rather than steel or aluminum. (Up to you to decide whether that's an advantage or disadvantage.)
Blocks (rear) and above-the-strut spacers (front) will not change the spring RATE. That is, the spring will still compress/deflect the same amount per pound of load as before. Ride quality should remain similar to what it was before the lift.
Stouter springs with a higher spring rate (less compression/deflection per pound of load) will make the unladen ride harsher. They will seem similar to the OEM ride quality only if you carry a heavy load ALWAYS.
Above-strut spacer kit installation instructions indicate no other required modifications (e.g., lengthening/relocating brake lines, modifying drive shafts, etc.
Strut part numbers:
Rancho RS5757
Monroe Sensa-trac: TS71100
Rear Shock
OEM Specs:
Ext Length = 24.050"
Comp Length = 14.840"
Travel = 9.210"
Upper and lower ends: bushing & sleeve, 1-11/16" bushing OD
Stock Length Part Numbers:
Rancho: RS5315
KYB Gas-a-just: 18193-05081267
Monroe Reflex: TS911277
Monroe Sensa-trac (coilover): TS58650
Gabriel Ultra: GABG63891
Non-Standard Length Part Numbers: (Min/Max)
Rancho RS5147 (14.610/23.070)
Rancho RS999147 (15.060/23.010)
xxxxxx
Feel free to copy/cut/paste any of that if it should prove useful.
I also have an article I wrote years ago on driveshaft vibration, cross-cardan U-joints (vs. CV joints), equal and opposite joint angles, joint phasing, etc. It's not Gen3-Dakota-specific, but parts of it might well still be useful in a FAQ discussion of lift blocks, whether they should be tapered or not, etc. Let me know if I should share it and with whom. (Edited: Heck with it. The article is here. Feel free to use as much or as little as you like if you think it useful and worthy.)
