A Sighn of what I'm in for?
Old Feb 17, 2011 | 10:14 PM
hendrixx324's Avatar
hendrixx324
Holly crap
Old Feb 17, 2011 | 10:29 PM
rengnath's Avatar
rengnath
Originally Posted by Eimer123
I would really like to know what plant everyone's truck came from. Mine was built in Mexico. Anyone else know where they built your truck? I am sure its on the inside of the door sticker.
My truck must be a built on the case of the Monday's.
Im not sure where the truck was built, but my Nightrunners say "Made in Mexico" on them.
You never want a Monday or Friday truck ....
Old Feb 17, 2011 | 10:42 PM
what number on the vin tells you what plant it was made in?
Old Feb 17, 2011 | 10:46 PM
Eimer123's Avatar
Eimer123
http://www.ehow.com/facts_7369158_do...in-decode.html
  1. [*]
Old Feb 17, 2011 | 11:02 PM
Eimer123's Avatar
Eimer123
What is kinda funny is that my truck vin decoder says it was built on the Dakota 4x4 line at Dodge City Assembly (Warren, MI), USA, but my sticker says built in Mexico.
I wonder if they are just referring to the engine.
Old Feb 17, 2011 | 11:04 PM
Blown287's Avatar
Blown287
My first three are 1D7
Old Feb 17, 2011 | 11:20 PM
thunder98110's Avatar
thunder98110
1B7, my truck must have been built by someone who had a really horrible day.
Old Feb 17, 2011 | 11:40 PM
Eimer123's Avatar
Eimer123
Vin#1
The country the vehicle was built in.
Possible choices are:
1 = USA
2 = Canada
3 = Mexico
Vin#2
The make of the vehicle
B = Dodge
D = Dodge
Vin#3
The vehicle type
4 = Multipurpose
5 = Bus
6 = Incomplete vehicle
7 = Truck
Vin#4
The GVWR (Gross Vehicle Weight Rating)
D = 1000-3000 lbs.
E = 3001-4000 lbs.
F = 4001-5000 lbs.
G = 5001-6000 lbs.
H = 6001-7000 lbs.
J = 7001-8000 lbs.
K = 8001-9000 lbs.
L = 9001-10000 lbs.
M = 10001-14000 lbs.
W = Bus or Incomplete vehicle
Vin#5
The line the vehicle was built on
E = Dakota 4x2
G = Dakota, Dakota Shelby, Dakota Sport, Dakota 4x4
L = Dakota, Dakota Shelby, Dakota Sport, Dakota 4x2
N = Dakota 4x2
R = Dakota 4x4
W = Dakota 4x4
Vin#6
1 = S (E)
2 = Dakota, Dakota Sport, Dakota SLT (AKA: Base (L)
Vin#7
Possible choices are: 1 = Wagon
2 = Club Cab or Sport Utility
3 = Club Cab
4 = Regular Cab
6 = Regular Cab
7 = Sport Utility 2dr or Step Van
8 = Front Section
9 = Open Body
A = Quad Cab
Vin#8
The engine
C = 2.2L (134ci) Carb I4 (The last assembly date is 6/15/88)
K = 2.5L (153ci) EFI
G = 2.5L (153ci) TBI I4
M = 3.9L (238ci) Carb V6
N = 4.7L (287ci) EFI SOHC V8
P = 2.5L (153ci) I4
T = 5.2L (318ci) CNG (compressed natural gas) V8
X = 3.9L (238ci) EFI V6
Y = 5.2L (318ci) EFI V8
Z = 5.9L (360ci) EFI V8
5 = 5.9L (360ci) EFI (HDC) V8
8 = 5.9L (360ci) Turbo Diesel V8
Vin#9
This is a mathematically computed "check digit" sort've like a checksum.
It can be used to compare the validity of the other characters in the VIN.
Assign to each numeric in the VIN its actual mathematical value and assign
to each alphabetic the value specified below:
A=1, B=2, C=3, D=4, E=5, F=6, G=7, H=8, J=1, K=2, L=3, M=4, N=5, P=7,
R=9, S=2, T=3, U=4, V=5, W=6, X=7, Y=8, Z=9.
Multiply the assigned value for each character in the VIN by the weight
factor specified for it below:
1st=8, 2nd=7, 3rd=6, 4th=5, 5th=4,6th=3, 7th=2, 8th=10, 9th=0 (check digit),
10th=9, 11th=8, 12th=7, 13th=6, 14th=5,15th=4, 16th=3, 17th=2.
Add the resulting products and divide the total by 11. The remainder is
the check digit. If the remainder is 10, the check digit is X.
Example VIN Characters: 1 G 4 A H 5 9 H 4 5 G 1 1 8 3 4 1
Assigned Values: 1 7 4 1 8 5 9 8 4 5 7 1 1 8 3 4 1
Multiply by: 8 7 6 5 4 3 2 10 0 9 8 7 6 5 4 3 2
Add products: 8+49+24+5+32+15+18+80+0+45+56+7+6+7+6+40+12+12+2=4 11 Divide
by 11: 411/11 = 37 4/11 Check digit:4 (compare to character in 9th position)
The check digit (9th position) will always be a numeric or an X.
Vin#10
Model Year of the vehicle
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
9 = 2009
A = 2010
Vin#11
The plant the vehicle was assembled in.
M = Lago Alberto
S = Dodge City Assembly (Warren, MI)
W = Toledo Assembly #3 (Toledo, OH)
Last Vin#'s
The assembly sequence of this vehicle on that particular line in this particular plant.
(i.e. its sort've like a serial number, but not for all Dakotas, just for a particular line)
Old Feb 18, 2011 | 07:34 AM
bain64's Avatar
bain64
Bought my 06' at 36,000 miles 2 years ago in May, now up over 50k. Besides some dummy backing into me the only trouble I've had is my windshield washer pump clogged up during the recent Blizzard. I guess I've been lucky. **knocks on wood** Hopefully I'll get that fixed this weekend.
Old Feb 18, 2011 | 08:42 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Eimer... wheres the J motor?
Anyways, I am sitting at 34k miles, bought it new. All that has went wrong is the driver side wheel bearing went out early and drove it for awhile blaming the sound on the tires until it got really noticeable and was replaced around 15k. Then some where around 20k I think it was, driverside front seat, bottom portion, the leather covering was replaced. It was coming apart at the one seam, and some of the leather was flaking in the same area. Other than that I have been lucky! I do have a squeak every now and again but I am sure I know what it is and its nothing major, just a rusty spring pack. Other than those lil manufacturing flaws, its been pretty solid.
