08 dakota problem
Old Feb 19, 2011 | 03:33 PM
smitty21's Avatar
smitty21
Question 08 dakota problem
So, i got a new dakota, 08, v8, flex fuel, quad cab, laramie 4x4..... So i have been driving it and have noticed a almost rubbing like, shutter on quick accelerations.
It only last a couple of seceonds. If i engage the 4wd i dont feel it.. Any i deas on what would cause this?????
Oh the truck only has 47,000 miles on it.
Old Feb 19, 2011 | 04:19 PM
dsimm87's Avatar
dsimm87
My 2wd will "shutter" sometimes when I take off on a semi-wet road. It's just the tires gripping/slipping/gripping/slipping repeatedly for a couple secs until full traction is achieved. Going into 4wd would eliminate this slipping.
Old Feb 19, 2011 | 04:37 PM
08XDakota's Avatar
08XDakota
I have a 2008 Dakota V6, I bought it new and i noticed that when I accelerate hard that it shifts hard (not hard but you could notice a little bump into 2nd) but from 2nd gear and so on it shifts fine. Sometimes in the morning when its cold out and im slowly accelerating it will almost feel like it jumps into 2nd, idk its hard to explain what happens...
Old Feb 19, 2011 | 09:30 PM
JimBio's Avatar
JimBio
Could it be your limited slip engaging? I notice the inside tire will do a few hops around turns when I accelerate, shakes the truck.
Old Feb 20, 2011 | 10:23 AM
Racinartist's Avatar
Racinartist
Is it AWD?
Old Feb 20, 2011 | 02:13 PM
rengnath's Avatar
rengnath
Any shake/vibration I have felt in my truck has been ruled to be the LSD in the rear.
I was in my dads AWD Taurus and it has the same vibration on accelerations and turns, but its alot worse than my truck. Almost feels like something is wrong if you dont know its AWD.
Old Feb 20, 2011 | 08:31 PM
smitty21's Avatar
smitty21
im sure its not the tires slipping/then gripping....it does it on dry surface as well.
The truck is 4x4 not awd.....it fells the it comes from the front mid are of the vehicle.
To me it almost seems like the 4wd is trying to engage but its not...
Old Feb 23, 2011 | 03:03 PM
keithhud's Avatar
keithhud
It may be the diff if you don't hear it when it's engaged.
On my 2WD I get the shutter only going around corners from a stand still. I try and take it easy given the tires I have.
