05 Dakota Lift
Old 03-09-2011, 12:09 PM
Rusty513's Avatar
Rusty513
Rusty513 is offline
Ok, one more post & then I'll stop bothering you guys, ha ha!!!! I think I may have this figured out. 2.5" spacers in the front, 1.5" blocks in the rear. Here's a link to the 265/75/16 tires I'm looking at
http://www.buywheelstoday.com/produc...dial+M%2FT.bwt
& a link to the wheels I'm looking at
http://www.buywheelstoday.com/produc...atte+Black.bwt
So you guys think this will work & look good & all I may have to do is trim the inner fenders some
  #22
Old 03-09-2011, 12:15 PM
dakota_raven's Avatar
dakota_raven
dakota_raven is offline
Well the two links are showing tires only!!!
  #23
Old 03-09-2011, 02:05 PM
Rusty513's Avatar
Rusty513
Rusty513 is offline
It's showing a tire & rim for me
  #24
Old 03-09-2011, 03:05 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
i dond see our wheel patern???
  #25
Old 03-09-2011, 05:43 PM
Rusty513's Avatar
Rusty513
Rusty513 is offline
Ok, try this link. This top wheel should work for me, right?
http://www.buywheelstoday.com/produc...lt.asp?id=4491
  #26
Old 03-09-2011, 06:22 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
this will help you determine what kind of wheel to buy and what kind of tire you can run on your new wheels..
Bolt pattern which all wheel manufactures list for our trucks is 5 5x5 which is 5 lug by 5 1/2" or 5.50 or 5x139.7
Back spacing on these wheels are 5 1/4" or 5.25
Offset for these wheels are positive offset of 1 3/8 to 1 1/2 or right around 38 millimeters
what seems to be the norm the more the the after market wheel gets closer to the centerline of the rim or 0 offset or in the negative offset, it reduces the tire size you can run because of it pushing the tire out away from the truck and then run into rubbing issues...
look at the sticky!!!
  #27
Old 03-09-2011, 06:25 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
i think this one is the winner???
Quick Reply: 05 Dakota Lift
