Where to get yellow fogs?
Old Mar 15, 2011 | 10:11 AM
BrandNew's Avatar
BrandNew
Default Where to get yellow fogs?
I am looking to get yellow fogs for my truck? I want the same size watts as factory. I have seen people put to high of a bulb and melt the wires. Does anyone know the factory watts?
Old Mar 15, 2011 | 11:08 AM
thunder98110's Avatar
thunder98110
ive got piaa 520 fog lights mounted in the factory holes. i previously had hella optilux fog bulbs that were the yelllow but they werent that yellow my piaas are awesome. i still have my hella bulbs they are the 37.5W with the 894 bulb.
Old Mar 15, 2011 | 12:10 PM
if you just wanting yellow bulbs, look on ebay for them, stocks are 9145. I've been running 9005's for a couple months now with no problems, but I have aftermarket housings (dont know if that makes a difference or not, but others have had their factory housings melt using 9005's, I replaced both of my factory housings because the lenses were cracked). If you want a yellow lens, you dont have many options but putting a yellow tint over the clear lens like ueland did. I had some 100 watt 9145 yellow foglight bulbs, but they burned out in a couple weeks, guess the wattage was too much, or they were cheap bulbs.
Old Mar 17, 2011 | 12:56 AM
Ueland's Avatar
Ueland
So you want these......?
I can tell ya how to get em, but its really gonna cost ya...
http://www.rvinyl.com/headlighttint/yellowsmoke.htm
With shipping its usually around 20 bucks for a 24"x24" piece. Just cut and do it yourself... plus with that much you can screw up a few times and still have extra/spare
I actually picked mine up on ebay. Can't remeber exactly what I paid for it, but was pretty close to what they sell it on their website for.
Old Mar 17, 2011 | 09:26 AM
BrandNew's Avatar
BrandNew
no I want the bulbs
Old Mar 17, 2011 | 09:51 AM
Factory are 45 watt I think. Here's some. There are probably cheaper ones.
http://cgi.ebay.com/ebaymotors/H10-9...Q5fAccessories
Old Mar 17, 2011 | 10:30 AM
BrandNew's Avatar
BrandNew
good find, thank you.
Old Mar 17, 2011 | 06:20 PM
Ueland's Avatar
Ueland
Originally Posted by BrandNew
no I want the bulbs
Oh.. check Rallylights.com then... they have some quality bulbs over there for a good price...
Old Mar 17, 2011 | 11:19 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
I like those ueland..so its just a sticky film you put over it? I think even advance auto sells this. How do you lop out the fog lamp lenses?
Old Mar 17, 2011 | 11:25 PM
Ueland's Avatar
Ueland
Not sure what you mean... For install I removed the fog lights from the truck, measured the size, then cut out a pice a little bigger then I needed so it could go around the sides a bit.
Start at the center and Install slowly. the film can stretch a bit just like window tint, and a heatgun is your friend. The stuff is self adhesive, but it works better if you float it with water like standard graphic/tint. once its on the front, cut any releif cuts in the sides to get a little wrap around on the edges.
That was it... they're not perfect, but neither are my original lenses. they pass the close up inspection test, and function great.. nice heavy yellow output...
