dakota amp question
Old Mar 21, 2011 | 03:06 PM
dakota_raven's Avatar
dakota_raven
Originally Posted by jkeaton
It you have the infinity system there will be an amp under the rear seat on the drivers side.
In my dak the amp is under the front passenger kick panel. You will need to re-wire the whole system unless you use one of this:
http://cgi.ebay.com/ebaymotors/2005-...fAudioQ5fVideo
Good luck!
Old Mar 22, 2011 | 12:00 AM
blacknightsix66's Avatar
blacknightsix66
Originally Posted by kwanczyk
what are you trying to power on that amp?
A guy who is a real audio head gets a bunch of free stuff from california and its all high end amps and speakers, but he is giving me a 1500watt amp and speakers to redue my stock system for a couple things he needed done.
Old Mar 22, 2011 | 12:06 AM
blacknightsix66
Can you take a picture of it? The amp for my infinity system sits under the rear seat on the drivers side, way back next to the wall.
This is what you might have i pulled the box, and thanks for your input.
Old Mar 22, 2011 | 12:08 AM
blacknightsix66
Originally Posted by BrandNew
Dodge sized that power wire for that amp. You need to run your own power, sized to your amp. You can use the remote wire(blue wire) to turn your amp on and off.
Thanks for making sure I wasn't going to use those wires, but i have 4 gauge that I plan on running
Old Mar 23, 2011 | 01:31 PM
blacknightsix66
Exclamation
Anyone know what this box is for??
Old Mar 23, 2011 | 03:45 PM
hmm...maybe that IS the satellite receiver or something. I gotta look at mine more closely, maybe thats not an amp under the back seat....thats kinda small for a "supposedly" 286 watt amp....
Old Mar 23, 2011 | 04:13 PM
atthewmartin114's Avatar
atthewmartin114
thats for the XM radio aka satilite radio. the amp is located under the passangers side of the dash behind the kick panal and it will say infinity on it and its got lots of fins and is black. as far as installing radios i have been doing it in ever car truck suv bus tractor boat even a few bikes well lets just say everything that i drive has some kind of bass. most times i use the factor amp. if you go to you local radio shack and tell him you need to comvert from speaker wire to an rca they will know what you need its a converter they run about 25 bucks. you intall them my hooking the lines to the speaker wire just before the rear speakers. (stock amp WILL NOT BE AFFECTED) this will allow you to connect to the after market amp. i do suggest not running the power wire threw the fender like most people that dont know cars do. but as far as connecting the remote wire. you can use an empty slot in the fuse panel and if tested with a test light can find the one that the key shuts off. i also do not suggest removing the rear plastics it will allow for loss of heat in the winter and fogging of the rear window when running a/c.
Old Mar 23, 2011 | 04:19 PM
atthewmartin114
both are installed in the back seat location of my 1997 dadge dakota club cab sport. there are two amps located under each passangers and drivers seat. together equaling 4400 watts. i have a secondary battery as a power supply. which is charged by a 0 gage power wire ran to the connection of the main battery. also a 12 gage alt feed from a true charge. both are fused with 100 watt fuses and i have a complete shut down switch to allow from extended parking and for winter when i remove the subs because there liquid cooled and will freeze.
Old Mar 23, 2011 | 04:40 PM
Backwoods18's Avatar
Backwoods18
Wow! Any pics??
Old Mar 24, 2011 | 12:39 AM
blacknightsix66
Thumbs up
Thank you and everyone else for your guys help on this much appreciated.
