dakota amp question
Old Mar 21, 2011 | 04:35 AM
blacknightsix66's Avatar
blacknightsix66
Arrow dakota amp question
I am thinking about installing a amp under my rear fold down seat in my 2006 dodge dakota and there is a little box under their and was wondering is that the stock amp? If this is just what I think it is could I tap into that harness for a input, as well as what else is in that harness?
Thanks
Old Mar 21, 2011 | 04:47 AM
Backwoods18's Avatar
Backwoods18
Welcome to DF and the 3rd Gen section! There are a couple people on here that have installed aftermarket systems. Do you have an extended cab or club cab?
Old Mar 21, 2011 | 05:05 AM
blacknightsix66
I have the quad cab SLT, and thanks for the quick response
Old Mar 21, 2011 | 06:23 AM
It you have the infinity system there will be an amp under the rear seat on the drivers side. Don't know if its possible to piggyback that amp.
Old Mar 21, 2011 | 12:35 PM
AlabamaWheeler's Avatar
AlabamaWheeler
I have the club cab and installed a mono sup amp under the driver seat.
Old Mar 21, 2011 | 01:12 PM
kwanczyk's Avatar
kwanczyk
what are you trying to power on that amp?
Old Mar 21, 2011 | 01:20 PM
blacknightsix66
I think I just have a basic set-up, but this morning I ask a friend and he said it could be for the satellite radio that came stock. I also took a closer look and disconnected that box and everything still work. So what do you guys thing it is?
Old Mar 21, 2011 | 01:25 PM
Can you take a picture of it? The amp for my infinity system sits under the rear seat on the drivers side, way back next to the wall.
Old Mar 21, 2011 | 01:30 PM
kwanczyk's Avatar
kwanczyk
i cant really have much input on here... i wish i could. i have a custom built box that fits behind the driver seat with the 40 split bench folded up it sits in that spot and the amp is mounted to the box... if you need help with wiring or things like that let me know..
Old Mar 21, 2011 | 02:38 PM
BrandNew's Avatar
BrandNew
Dodge sized that power wire for that amp. You need to run your own power, sized to your amp. You can use the remote wire(blue wire) to turn your amp on and off.
