rusting through my rear fenders. suggestions on where to get it done? MI
Old Mar 21, 2011 | 08:15 PM
kwanczyk's Avatar
kwanczyk
Default rusting through my rear fenders. suggestions on where to get it done? MI
i got rust coming all the way through and its working its way up the side of the truck. i plan on putting bushwacker extend a fenders but im trying to think of the cheapest way to fix the rust.... any suggestions?
Old Mar 21, 2011 | 09:37 PM
rengnath's Avatar
rengnath
Sand off as much as possible and seal it with a protective paint like Rustoleum (they claim you can paint right over the rust if you want) or do a rubber protectant. It wont be pretty, but itll do the job.
Old Mar 21, 2011 | 10:28 PM
front or rear? you can get a new fender from rock auto for @$50.
Old Mar 21, 2011 | 11:12 PM
o6dakota's Avatar
o6dakota
Typically speaking the rust you see on the outside is 2-3 times as large on the inside of the panel the best cheap fix would be to see how for up the flares fit on the box. Cut enough of the sheetmetal to remove as much rust as possible. And use a rust encapsulator por-15 (for the people who think im pushing product) there is also some stuff out there called silver bullet and eastwood has a house brand encapsulator. This would be the best way for longevity. The only rt way to do it is put 2 boxsides on. If you patch the metal in anywhere you weld that you cant get to the backside to corrosion protect will be instant breeding ground for new rust.
Lance
Old Mar 22, 2011 | 01:39 AM
Eimer123's Avatar
Eimer123
Mine is the same way after this winter, rear has rusted horribly. The problem is they did a horrid job or pinch welding the bed and side panel. The only way to fix it properly is to separate the entire pinch weld and repair it from the inside.
This was before the winter, it is much worse now
Old Mar 22, 2011 | 01:49 AM
sl2racer's Avatar
sl2racer
i thought dodge had a seperate warranty for dealing with rust. it may be on the frame only though.
Old Mar 22, 2011 | 05:09 AM
Backwoods18's Avatar
Backwoods18
I am getting rust on my front fenders behind my headlights so when ever it rains the rust colors run down the bumper :/
Old Mar 22, 2011 | 09:16 AM
Racinartist's Avatar
Racinartist
Just because it's on the internet doesn't make it fact. So take it for what it's worth, but I'd definitely check with a dealer to see if it's covered. And do it BEFORE attempting to mount any aftermarket flares/splash guards.
http://www.autotropolis.com/warranty...-warranty.html
"The rust warranty covers the sheet metal on the outside of the vehicle. Any holes that are caused by rust corrosion are covered under this warranty. A surface chip or rusted area is not covered, nor is scratched paint. This warranty is good for five years or 100,000 miles."
Old Mar 22, 2011 | 02:30 PM
graythang's Avatar
graythang
That’s just wrong. I had mine undercoated as part of my deal and I had to tell the idiot where he was missing. I live in FL so salt from snow removal is not a problem but still these trucks rust like they where ten plus years old. My oil pan is almost rusted all the way through and I hope I can dump this bucket before I need to that $750 replacement repair. The front sway bar end links where so rusted that they lost 50% of the weld area to rust. I just replaced them over the weekend. I had the front body cross member the one in front of the radiator repaired twice under warranty because of bubbling rust. My buddy's 1996 T-100 Toyota has no rust and he lives beachside. I can’t even imagine my truck beachside.
Old Mar 22, 2011 | 02:45 PM
kwanczyk's Avatar
kwanczyk
this is not half bad compared to mine lol... i think what im going to do is contact dodge and see if im covered under the rust warranty, and if not ill spray rustoleum and then clearcoat it and then throw the bushwackers over it...
