Electric Fan wiring question
Old Mar 26, 2011 | 12:59 PM
Dakkkota's Avatar
Dakkkota
thanks but can you show me what you are talking about..autozone does not exist.
Old Mar 26, 2011 | 01:00 PM
Dakkkota's Avatar
Dakkkota
in canada
Old Mar 26, 2011 | 01:03 PM
Blown287's Avatar
Blown287
Originally Posted by Dakkkota
in canada
My bad brother, here you go.
http://cgi.ebay.com/ebaymotors/DERAL...#ht_500wt_1182
Old Mar 26, 2011 | 01:17 PM
Dakkkota's Avatar
Dakkkota
Originally Posted by Blown287
thanks...but i dont need any temp signal of the stock sensor pluged to the 4,7 harness right?
and what up up i swap to a 180degree thermostat???
Old Mar 26, 2011 | 02:13 PM
Blu3P0ny's Avatar
Blu3P0ny
Ok... anyone know what kinda of signal the stock sensor sends? Does the SPAL use a varying voltage from the sensor? I was kind of hoping the stock sensor would be an on/off type and I could hook a relay, BUT, I guess I could piggyback it and just have some sort of trigger to activate at the temp I want.
Does anyone know what readings it gives ya?
Old Mar 26, 2011 | 02:30 PM
Blown287's Avatar
Blown287
If you sent them a message on ebay they can put together just about anything for you cheap. You can use the stock temp sensor or use one of their aftermarket sensors.
Old Mar 26, 2011 | 04:55 PM
ReturnToSender's Avatar
ReturnToSender
Yes Spal uses a varying voltage.
DESCRIPTION
The Engine Coolant Temperature (ECT) sensor is used to sense engine coolant temperature. The sensor protrudes
into an engine water jacket.
The ECT sensor is a two-wire Negative Thermal Coefficient (NTC) sensor. Meaning, as engine coolant temperature
increases, resistance (voltage) in the sensor decreases. As temperature decreases, resistance (voltage) in the sensor
increases.
OPERATION
At key-on, the Powertrain Control Module (PCM) sends out a regulated 5 volt signal to the ECT sensor. The PCM
then monitors the signal as it passes through the ECT sensor to the sensor ground (sensor return).
Old Mar 26, 2011 | 05:44 PM
Hammond_Egger's Avatar
Hammond_Egger
Thanks for the settings, Blown...
Thanks to everyone else as well, I am enjoying this post so far
