airbag lights are on (both of them)
Old Mar 26, 2011 | 07:45 PM
cheeseburger's Avatar
cheeseburger
Unhappy airbag lights are on (both of them)
I've tried disconnecting the battery overnight, i've tried grounding the positive lead. ive pulled the airbag fuses (all three of them) i've disconected and reconnected the seat sensors i've made sure there is nothing in on or around the seat. and all this started after i pulled out my seats to put in my sub, the first time i pulled it out everything was cool no problems... but this time both lights are on. im at the point now where im ready to just say F*** it and roll without airbags. i know the dealer can recalibrate the load cells in the seat but thats my last resort.. im broke atm cause i just had to replace a front wheel bearing... (100 bucks) anybody got any more ideas. ive tried using a dtc computer and the computer throws no codes. ive used the onboard method of holding the trip button and turning the key to acc and it gives me a code of hr2479 which doesn't exist... and when i start the truck the check engine light flashes 10 times in a row (no pattern) and goes off... now wtf do i do.......: confused:
s
Old Mar 26, 2011 | 08:27 PM
Backwoods18's Avatar
Backwoods18
Oh, man. I don't mean to get your hopes up, as I don't have an answer. I just hope you find your answer and everything works out!!
Old Mar 26, 2011 | 08:30 PM
cheeseburger
hey backwoods i been meaning to ask u something.. do you know what your 3/4 ton springs came out of. i've been thinking about doing that swap. i know ur truck came with them but do u know what they came out of?
Old Mar 26, 2011 | 08:37 PM
Backwoods18
They came out of a 2006 Ram 2500. If you have any other questions PM me or even better, get at me on Facebook. (I can access FB at work and DF I can't)
Old Mar 27, 2011 | 02:32 AM
italiandominator's Avatar
italiandominator
I had the same issue when I did my stereo install. I took everything out: seats, center console, radio, radio bezel, the works. Turned out when I put everything back in I plugged everything back the way it was just right except one thing. the little black air bag light between the air vents above the radio. Once I reconnected that, everything was fine.
Old Mar 27, 2011 | 02:46 AM
cheeseburger
its definitely plugged in. its lighting up.
Old Mar 27, 2011 | 06:08 PM
italiandominator
sorry thats all Ive got, unless, you have already gone to a local guy or dealer to see if they could simply/cheaply try and just clear the phantom code that is making it light up. *shrug?
Old Mar 27, 2011 | 06:42 PM
ReturnToSender's Avatar
ReturnToSender
Do the lights go off if someone is sitting in the passenger seat?
Old Mar 27, 2011 | 07:43 PM
cheeseburger
nope they dont shut off.
Old Mar 28, 2011 | 01:35 AM
Ueland's Avatar
Ueland
Are you showing any codes??
