BLOWN287'S how to HHR e-fan conversion?
Old Mar 29, 2011 | 05:37 PM
Dakkkota's Avatar
Dakkkota
Default BLOWN287'S how to HHR e-fan conversion?
i cant find it... Im about to start this...
Last time When i tried to remove the fan from the engine while tried to performed the b-lift i never been able to loosen it!
how do i do??? i tried with a key wrench and the belt was slipping and tried to hit the key with a BFH...no better result.
Old Mar 29, 2011 | 07:58 PM
Cuban11182's Avatar
Cuban11182
Thumbs up
Problem SOLVED!!
When you turn the wrench the vice grips will push against that stud that sticks out.
File Type: jpg
Old Mar 29, 2011 | 08:08 PM
Eimer123's Avatar
Eimer123
What I did was take 2 peices of steel, bolted one end together, and put two bolts that fit in the pully holes. Looks just like a adjustable pin wrench for a hand grinder.
Kinda looks like this...
Old Mar 29, 2011 | 08:23 PM
ruger226's Avatar
ruger226
I used a chizzle and smacked the edge of the nut a few whacks and it will come off.
Old Mar 29, 2011 | 09:59 PM
Blown287's Avatar
Blown287
Here you go.
https://dodgeforum.com/forum/3rd-gen...installed.html
