Exhaust cost
Umm a ticking sounds lol. They both sound very similar. Even if the noise goes away after the truck warms up, it still can be either. Only way to find out is to get in there and look to see if your bolts are snapped. you could also buy some Seafoam and pour some into the throttle body and when it starts smoking, look at the manifold and look for smoke leaking out.
I had the broken driver's manifold bolt....If it is this, it will get louder over time (will almost go away completely when the truck is warmed up).
I also have loud lifters, but they go away after about 3 min after starting.
I went with headers and locking bolts....never to worry about it again (I hope!)
Aargh, ya beat me to it. Ya just like he said, take a wooden dowell rod (works just as fine) hold it to the exhaust mannifolds, and valve covers and if you hear a tick, you got the source of the problem.
That sounds exactly like my situation.
tomorrow I'm going to get a quote in a local shop for headers and full exhaust....we'll see how that goes..
If it's a slight exhaust manifold leak, it will likely go away after the engine gets heat in it and expands the metal enough to close the offending leak.
If it's the notorious valve lash adjuster 'tap', that tends to quiet down after the engine heats up but it won't go away.
Both emit a tapping noise but they each have a distinctive sound. It's hard to explain but that's what I've found.
