DiscBrake noise.
Need some help With this.
Less than 45,00 miles on my '05 dakota. when I apply my brakes I hear noise from the front discs. Squeaking,grinding,not cotinual I guess it would be intermittent.Goes away after using the brakes for a while . Brakes function well,no problems stopping,pedal good. Replaced pads 2 times,Same problem after a couple of weeks. Discs have been surfaced,got quiet then came back.
I think it is my discs they are original. What do you guys suggest / replace ? can i get better quality discs at O'rielly or where?
First let me say welcome to DF and the G3 Dakota section.
I use carbon metallic disc and you can buy those at O'reilly's.
http://www.oreillyauto.com/site/c/de...0068&ppt=C0009
A lot of guys on here use the drilled/slotted rotors.
No noise when tire wheel is raised . Spun by hand. suspected wheel bearingbut it only makes noise when brake pedal is applied. I suspect is is the rotor,I have heard OEM is sometimes pretty cheap quality.
Thanks for welcoming me. I am glad to have input from other enthusiasts and persons who went thru it also.
