SuperChips?
Old Apr 30, 2011 | 08:49 AM
Originally Posted by wingman_214
Performance 91 tune on 87 octane with 195 thermostat. stock shift schedule at part throttle and superchips at WOT.
Any issues running the 91 tune on 87 octane?
Old Apr 30, 2011 | 09:14 AM
wingman_214's Avatar
wingman_214
No issues yet. Even in 110 degree heat. It does make me a bit nervous though.
Old Apr 30, 2011 | 10:29 AM
Six_Shooter's Avatar
Six_Shooter
Originally Posted by jkeaton
They dont make one for the 3.7.
Not directly, but there are people on here that are saying that it can actually be done.
Old Apr 30, 2011 | 03:36 PM
damyankee84's Avatar
damyankee84
I run the 87 tune and used the pre-installed TM settings (didnt want to pay for the self adjustment settings yet) I would recommend changing the tire size settings. Because it sets it at 28" but mine measured 28.5", not surre if it made a difference but every little thing helps.
Old Apr 30, 2011 | 08:54 PM
rengnath's Avatar
rengnath
I had to calibrate my tire size via the speed on a GPS. My tires were measuring way more than what I have the size set at to make the speedo accurate.
Old Apr 30, 2011 | 09:09 PM
I want to know if anyone else runs the 91tune on regular gas.......if so then the sc tunes for 87 and 91 are all hype
Old Apr 30, 2011 | 09:56 PM
rengnath's Avatar
rengnath
There is no "hype" ..... just Superchips covering their butt. To put it simply, Superchips tunes arent very aggressive in the terms that they dont push the limit of performance to the fuel being used. Because the tuners are used all over, with people using different qualities of gasoline, they have to be very conservative when it comes to tuning. Remember, its the quality of the gas that matters. A quality fuel rated at 87 octane can be alot better than a crappy fuel rated at 93 octane. If you use quality fuel, you shouldnt have to really worry. Listen for pinging. If you are still worried, pull the spark plugs and look to see if there are any signs of pre-det on the ceramic.
Old Apr 30, 2011 | 10:19 PM
wingman_214
Cool
Thats exactly why i run 87 octane. And 87 will give more hp as long as your engine is able to run within its limits.
Old May 1, 2011 | 12:33 PM
Gotcha...91 tune here I come...as long as it don't eff up my shift schedule....
Old May 2, 2011 | 07:31 AM
rick4dak's Avatar
rick4dak
SC tuner was the best thing that I have added to mine. I tried the 91 octane tune and got more power (longer burn-outs) than 87 tune. I agree with the above about good gas vs. crap gas.
I towed a trailer about 3000 miles in January with the towing tune. It worked great - 14mpg, 87 octane gas, never missed a beat. I did notice that the tailpipe was black when I got home. It must set the mixture fairly rich.
