Struts and shocks
Old May 19, 2011 | 09:09 PM
tpartee 05's Avatar
tpartee 05
Default Struts and shocks
I'm replacing my struts and shocks on my '05 dakota but I am unsure of which ones to use. Monroe or Rancho. Does anyone have experience with the monroe self leveling shocks for the rear? Are they better/worse than the rancho shocks. I have a camper shell on my truck and also carry paint supplies in the back that weigh the truck down. If I put a leveling kit on the truck will the monroes keep the truck from sagging in the rear under load? Thanks for any help
Old May 19, 2011 | 09:14 PM
Dakkkota's Avatar
Dakkkota
i suggest the munroe and the rear coil over it you have a camper with a leveling kit....
rancho un front if you dont level it
Old May 19, 2011 | 09:24 PM
tpartee 05's Avatar
tpartee 05
Thanks for the quick reply. I searched earlier and read through most of the threads but couldn't find a good answer. I've had this truck for 3 months and put 6k miles on it and have replaced the tie rod ends, sway bar links, rack and pinion, and now replacing lower ball joints so I figured I might as well replace the shocks on it while I'm at it. Thank you!
Old May 19, 2011 | 09:33 PM
i swear mine must have had all the front end stuff replaced at some point before I got it, I have almost 70k and had the front end checked out when I had an alignment check done a month ago, they said everything up front is solid. I am replacing my struts because it is a tad too bouncy for me, but the other stuff is fine.
Old May 19, 2011 | 09:36 PM
wingman_214's Avatar
wingman_214
I would recomend the load leveling shocks. They are a coilover design that will give you about 500lbs more load capacity. They will provide more stability and your truck will squat less when loaded.
Old May 19, 2011 | 09:40 PM
tpartee 05's Avatar
tpartee 05
Mine's to bouncy for my liking too. Reminds me of the old lincolns and cadillacs from the 70's. Well not that bad but close.
Old May 19, 2011 | 10:17 PM
tpartee 05's Avatar
tpartee 05
Perfect. Thank you
Old May 20, 2011 | 06:11 AM
Backwoods18's Avatar
Backwoods18
That is exactly how mine is. Brand new everything except struts. I would run Rancho's up front and monroe coilovers/self levelers in the back.
Old May 22, 2011 | 06:00 PM
mauricio4x4's Avatar
mauricio4x4
i dont understand sorry..
in the rear just change the shocks right?? why you guys talk about coilovers at the rear?? the dakota has leaf springs!!
reagrding the front, which rancho model? does rancho has struts for dakotas??
I found this post in the web, it looks that maybe could be used in the dakotas. Is a rancho quicklift on a Ram 1500, it has the same bottom mount that the dakotas.
what do you think? will it fit on dakota 2010?
http://www.*********.com/forums/show....php?p=3047407
Old May 22, 2011 | 07:14 PM
wingman_214
http://catalog.monroe.com/catalogPar...dStatus=ACTIVE
Kind of like an add a leaf.
